R380 reverse switch - Defender Source
Old December 29th, 2008, 08:49 PM
R380 reverse switch
I need to replace mine, and ordered it from RN. I got a response back asking me to confirm R380 vs LT77. When I confirmed R380, they said they need to order from UK. I have til friday, then I'm gone until April and was hoping to get my reverse lights fixed before I left. I'm trying to figure out what the part # is and if someone else has it now. Seems it should be pretty common part on hand. AB lists it as AMR3918, can anyone confirm that's the right part # or not? Is this usually stocked by dealership parts?
Old December 30th, 2008, 01:01 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I may have a used one if you need it. Am shipping some items tomorrow if you can not find new.
JP
legend in my own mind
Old December 30th, 2008, 10:34 AM
Thanks Jim. AB had the AMR3918 in stock, so I'm rolling with that. Looks the same as my failed one online..hope that's the case.
Old December 31st, 2008, 12:15 PM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
I had mine go bad - turned out it was just one of the wires had broken - a bit of solder and some heat shrink, and it was good as new!
Old February 15th, 2010, 10:25 PM
I'm back now and working on this (didn't get it done before I left). The switches look to have a 2 bladed male weatherpack style connection, but my loom doesn't have the proper female connector. Anyone know what kind of female connector it is and where I can find one? would rather correct main harness than have to modify both with aftermarket.
Old February 15th, 2010, 10:51 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
You're back before April
I might have the connector in a pile, I'll look tomorrow.
Keith
Big, Red and ... aaa Red..
Old February 15th, 2010, 11:18 PM
Sweet! I just did a little research and it is an AMP connector.
Just got back last week and on paid leave until April...and loving it. Had my first REAL beer since leave in June. I just dumped St. Pauli NA for good.
r380, switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Reverse Lamp Switch Wiring fleabus Defender Technical Discussions 7 April 16th, 2006 11:58 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
