R380 Rebuild - Defender Source
Old October 10th, 2011, 01:05 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
R380 Rebuild
My transmission went out on me again (2nd one) outside the Holland Tunnel. I didn't know what it was but it just wasn't going into gear. I was hoping it punched through the fork or something easy... but after inspection wasn't.
After about 8 tries we got the truck up on the "lift" and I ripped out the transmission and transfercase. I noticed right away the shafts on the r380 did not spin together in any gear. So I ripped the case apart to find the main shaft was sheered in two! The spline was in perfect condition so the weak spot was in the metal.
Does anyone have an r380 part number list? I know I need a new main shaft, main shaft bearing. I think 5th gear spacer and an oil pick up seal or something like that. I guess I could show these photos to RN and they should piece me together the bits I need.
ID:	42617   Click image for larger version
ID:	42619   Click image for larger version
ID:	42621   Click image for larger version
ID:	42623   Click image for larger version
Old October 10th, 2011, 05:24 AM
I would try RDS
Old October 10th, 2011, 06:38 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Try these t o see what parts you need.
http://www.numcat.ru/landrover/4/31/8449/
http://lrcat.com/#31/3/8449
Land Rover 110
Old October 10th, 2011, 09:55 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Well since you have everything apart you shoulddddd put in a Xeng hand brake.)
Might also want to look at what lucky8 has from ashcroft as well.
Old October 10th, 2011, 11:30 AM
ini88's Avatar
ini88
Daniel Marcello
Good call on George. Him and TLR were my other guesses for parts. lrseries.com looks to have a lot of them. so im going to cross reference PN#
Old October 10th, 2011, 02:02 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Rob D. in ABQ is fantastic, if you choose not to rebuild it yourself.
1970 SIIA 88, Sold
Old October 10th, 2011, 04:46 PM
If it is the same main shaft, I have a TD5 trans you can have for short money.
Old October 10th, 2011, 05:40 PM
Suffix J box?
Old October 10th, 2011, 06:13 PM
ini88's Avatar
ini88
Daniel Marcello
Yeah should be a suffix J box. Was out of a '95 NAS. I think the J and K,L boxes have a different main shaft.
Ron, I will PM you. TD5 is a suffix L right?
Old October 10th, 2011, 06:24 PM
td5 box works wirh 300 not v8
r380, rebuild
3.9 engine, R380 transmission Shane@EVS For Sale - Parts 7 August 3rd, 2006 04:04 PM
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
