R380 new noise - Page 3 - Defender Source
Old February 13th, 2013, 10:32 AM
Sounds good Doug thanks. I actually read back through this thread after I wrote that and saw your comments. I've asked Ashcroft for the dimensions and weight of the crate. Will DHL allow me to pick it up and take it since I'm there for paperwork? Wondering if it will fit in back of the 110. I have floor boxes so my floor is 8" higher than normal.
Mark Kellgren
KM4BOR
Old February 13th, 2013, 10:41 AM
Expect a SNAFU with the paperwork. DHL is just about the most useless collection of human incompetence on earth. They don't know the difference between an air bill, a waybill, and a bill of lading. They will probably have it at some warehouse miles away from the airport, and you'll have to bounce from the airport Customs office to the DHL office to the warehouse several times.
Go early in the day and expect it to take several hours. If it goes smoothly, bonus.
Old February 13th, 2013, 12:05 PM
Mine was on a pallet. I left the pallet with dhl. You have to go to DHL- then customs -then back to DHL
Old February 13th, 2013, 02:05 PM
Thanks for info. Thinking ahead on this swap out, do I need any grease or hylomar for this? I've never pulled the T-case or tranny on a Rover before, but I've seen some mention of hylomar somewhere, as well as grease on mainshaft. Not sure what type of grease and where all to use it. Throwout bearing?
I have fresh MTL on hand for the tranny. what else do I need?
Mark Kellgren
KM4BOR
Old February 18th, 2013, 05:23 PM
Ashcroft notified me that tranny should arrive at Charlotte Douglas today, so disassembly has begun!
Mark Kellgren
KM4BOR
Old February 19th, 2013, 03:35 PM
Went to US customs today with paperwork provided by DHL, wrote a check for $42 and left 20 min later for DHL. Wrote a check to DHL for $70 and left with my tranny! Painless! Now I'm going to drain fluids and pull propshafts as my goal for rest of day
Mark Kellgren
KM4BOR
Old February 21st, 2013, 05:32 PM
T-case out today. That was much easier than I thought! So glad I had that tranny jack. x-brake would hv made it even easier! (on wishlist)
this is what I got when draining the tranny
Mark Kellgren
KM4BOR
Old February 21st, 2013, 09:32 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I usually do the full clutch kit, pilot bearing, flywheel, pressure plate, clutch disc and throw out bearing, for the $300-$400 it is it is worth it considering you are already in there.
Old February 21st, 2013, 10:11 PM
yep. that's what I have, sitting in it's box on the crate picture. (sans the flywheel)
Mark Kellgren
KM4BOR
Old February 22nd, 2013, 07:39 AM
lets see the transmission main shaft splines.
Old February 22nd, 2013, 07:44 AM
which side? input output or both?
Mark Kellgren
KM4BOR
Old February 22nd, 2013, 08:43 AM
output
Old February 22nd, 2013, 09:18 AM
here u go. new tranny pic
Mark Kellgren
KM4BOR
Old February 22nd, 2013, 09:35 AM
Glad it was an easy pick up
Old February 22nd, 2013, 09:41 AM
That wooden crate is a lot smaller that the pallet he shipped mine on. Guess thats why shipment with DHL was less.
Old February 23rd, 2013, 03:55 PM
cleaned up T-case today. put in new input shaft and front output seals (rear output done couple months ago). confirmed I have cross drill input shaft
mated R370 to t-case. The fact that I was able to lift the T-case and R380 (seperately) made assembly much easier. I won't even need my engine hoist. The transmission jack is enough.
Tomorrow I'm hoping to pull out old transmission so I can install new clutch kit and transfer the bell housing.
Mark Kellgren
KM4BOR
Old March 15th, 2013, 07:55 PM
All done. Back on road again 2 weeks ago and new transmission is smooth as silk. Runs like a new truck.
Thanks everyone for all the great advice.
Name:	Post tranny install.jpg
Mark Kellgren
KM4BOR
Old March 15th, 2013, 10:42 PM
Awesome, I know you are glad to have it back on the road, what did you do with the old gear box?
Old March 15th, 2013, 10:43 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
For what it's worth, Rob Dassler (RoadsideRob) at Southwest Rovers does very nice rebuilds of LT230s and R380s. His prices are not far off (if at all...) the Ashcroft prices and he usually has some freshly-rebuilt units ready to ship from his shop in Albuquerque. He's also a really good guy and easy to work with.
Old March 15th, 2013, 10:53 PM
back in the crate in the garage, waiting for a possible attempt at a rebuild down the road. It was fully functioning, but just had a noisy layshaft bearing. A rebuild kit from ashcroft would have me a spare someday.
------ Follow up post added March 15th, 2013 10:55 PM ------
I did talk to Rob, and he didn't have any on hand. Plus, it was over $2k for a rebuild from him with core, plus shipping charges of the core and rebuild back and forth. So that made ashcroft with no core charge faster and cheaper. The one thing he has going though is the warranty stateside.
Mark Kellgren
KM4BOR
r380
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
lifted d 90 noise 4x4x46 Defender Technical Discussions 11 June 15th, 2005 07:29 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
