R380 / LT230 Removal - Defender Source
Old July 6th, 2014, 08:48 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
I've got a 5th gear "buzzing" in my R380 that I've been told is a layshaft support bearing. I am in the decision making process regarding an Ashcroft rebuild and have started to look into the removal and refit.
I have a 300tdi with R380 and LT230 driveline. I have pulled and replaced a few Series III gearbox/T-cases using an engine hoist and out the passenger door method. Is it possible to drop the R380/LT230 down through the bottom and onto a pallet using the same hoist? I do have a heavy floor jack and have seen adapters intended for transmission removal - I assume that, despite the weight rating, I will not be able to remove the R380/LT230 together with this tool?
Also, the manual indicates the radiator needs to be drained, exhaust unhooked, etc.? Are all of these processes necessary? I have learned using the Series Land Rover "Green Bible" that with a little ingenuity a lot of these processes are unnecessary - is that the case with the Defender?
Thanks in advance,
Henry
www.shearpin.org
lt230, r380
Cigar Lighter Removal and Rear Wiper Switch Removal isleofbones Defender Technical Discussions 6 April 13th, 2013 08:02 PM
R380/LT230 compatibility rover4x4 Defender Technical Discussions 5 May 11th, 2009 03:32 PM
R380 transmission, LT230 transfer case and Diff themaxx For Sale - Parts 4 December 21st, 2007 09:33 PM
R380 LT230 Fluids ronward Defender Technical Discussions 13 September 21st, 2006 11:28 PM
Wanted: 94 D90 Transmission R380 & Transfer Case LT230 WOVOKA Wanted 1 June 11th, 2006 01:23 AM
