R380 Leak Help - Defender Source
Old June 17th, 2011, 02:10 PM
NoVaKevin
Kevin
sold#1469
R380 Leak Help
R380 leak on the shifter part. So, went to get an estimate for my exhaust and there was a leak coming from the r380. I took the tunnel cover off and its actually on the belltower (me thinks that is what it is called)- the shifter part on the left side. Is this an easy fix? Looks like it should be. Is the seal a paper/cork gasket or is it RTV? See pic for right and left side of belltower.
THe transmission only has 3k miles on it and is from RoversNorth.
Name:	Left Side Belltower.jpg
ID:	39728   Click image for larger version
Name:	Right Side Belltower.jpg
Old June 17th, 2011, 04:37 PM
I don't see a leak
Old June 17th, 2011, 04:50 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
LEAK... that's no leak.
Weldon
Old June 17th, 2011, 06:23 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
X 3.
John Karlsson
Hope Valley, RI
Old June 17th, 2011, 06:27 PM
NoVaKevin
Kevin
sold#1469
x4
I shouldve figured that was coming. Trust me, when we looked at the exhaust, it was creating a puddle, and it was burning as it hit the exhaust.
I talked to RN. I took it off, put on some permatex, and will see if that works tomorrow. My issue was that the d90 repair manual that I have is for RHD, and the diagram showed that part had a nut for the adjustment for 5th gear. But, its different on a LHD NAS90 with reverse bottom right.
r380
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
