R380 Lateral Runout - Defender Source
Old September 11th, 2011, 10:55 AM
trybul
Craig Hobbs
D90 83
R380 Lateral Runout
Hey,
So it has been a long couple days. I have been trying to diagnose the reason for the clutch drag we are experiecing..
As such we pulled the tranny again, and measured the Runout of the input shaft. The in/out play was with in spec at only .02 where the manual says that is should be between .01 and .06.
Now we could not find a value or Spec for the lateral runout or axial play, but when measured we came up with a value of 1.5 mills. Not sure what tolorance is for this, Hope someone knows so that we can rule out wether i have a bent input shaft/ it is causing the clutch drag.
Thanks for all the info guys.. it is greatly appreciated.
craig
Old September 11th, 2011, 03:06 PM
Input shaft radial play should not matter. The pilot bearing should be controlling the input shaft at the clutch.
r380
3.9 engine, R380 transmission Shane@EVS For Sale - Parts 7 August 3rd, 2006 04:04 PM
r380 diesel/v8 question D90user Defender Technical Discussions 5 January 1st, 2006 07:15 PM
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
New R380 willtillery For Sale - Parts 1 November 29th, 2004 10:04 AM
r380 200 miles willtillery For Sale - Parts 4 March 8th, 2004 10:43 AM
