R380 : how much 2nd gear crunch can be expected? - Defender Source
Old August 24th, 2012, 01:30 PM
84ninety
84 tdi
Someone telling me they all do that after 80-100k miles. Is this Accurate? Or jsut glossing over a 1500 dollar repair?
Old August 24th, 2012, 01:39 PM
Akitatw4's Avatar
Akitatw4
Tom
1995/D90
I just rolled 124K and have to say 2nd is the crunchy gear, but only sometimes. I am no expert, so take my opinion with half a grain of salt.
"Be Polite, Be Professional, but have a Plan to Kill Everyone You Meet." - Gen. James Mattis, USMC
1995 NAS D90- Alpine White 'Oink'
Old August 24th, 2012, 02:11 PM
robertf
Robert F
1995 Discovery
215 on my disco and 3rd is the most crunchy. 2nd isn't too bad
Old August 24th, 2012, 02:30 PM
the rover shop
shayne young
2nd gear being the most commonly used synchro is usually the first to go..anything more than a 2-3 second change is considered in need of replacement..I.e..2-3 seconds from 2nd to 3rd..
Old August 24th, 2012, 02:48 PM
if you adapt your gear change and don't crunch it it won't get any worse ... you don't have synchro on reverse and you're not worried about that are you?
keep the redline in there ... makes a huge improvement ... let the revs drop between first and second or blip the throttle when in neutral and it will probably last forever.
Old August 24th, 2012, 03:07 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
When I first started driving my 90 I was crunching 2nd gear about 60% of the time. After some time with the vehicle and getting to understand the rhythm of the tranny, it's rare to crunch. Get in synch with the synchro and all will be good.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old August 24th, 2012, 03:25 PM
after helping change a gearbox on my friends truck i'd learn to live with it ...
Old August 24th, 2012, 05:05 PM
r380 has synchro reverse.
Yes, use the redline. Sometimes I push the lever over to the other side of the H before going up into second. It doesn't really do anything but it provides the necessary pause. Switching to the Redline MTL made the biggest difference though and mostly I do not need to do that anymore.
Be sympathetic to the limitations of the machine and learn to live with the pace it is happiest at, and it will last lot longer than if you treat it like you expect it to be something it is not.
Gearbox changes are doable for the home mechanic but are time consuming and expensive. Therefore most people live with minor gearbox faults and idio-synchro-sies if the unit otherwise has alot of life left in it.
Old August 24th, 2012, 08:58 PM
3rd gear can be notch if I am dogging it, otherwise month when it warms up. I attribute it to driving it like a truck and running MTL for the past 50k.
Old August 24th, 2012, 11:19 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
3rd crunches for me on occasion.
Higer revs and a longer pause between gears minimizes it...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old August 25th, 2012, 04:32 AM
CDeWan
Clay DeWan
5.3L beastie
LT77 went out so that was a crunchy 2nd. I finally just got sick of the crunch and it was getting worse. Had no problem with the used R380 I stuck in it until a little piece of casting that holds the 5th and reverse fork in place (I am totally screwing this description up) broke off - it is a plate with 2 bolts and a casting that looks like an upside down U. Anyone else ever had that piece break?
Old August 31st, 2012, 02:33 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Don't know if you can get Castrol Syntrans 75W-85 over there, but in my experience and most in Oz that have run MTL and Syntrans it improves the shift quality over Redline MTL or the MTL/MT90 blend I ended up with.
Having said that, R380's can be idiosyncratic and the odd 'box still shifts better with something like Valvoline DuraGear 75W-85 or even ATF, so go figure.....
FWIW I run Motul Gear 300 these days anyway.
Much better at high ambients/high loads than MTL or Syntrans and still shifts well at just under 0*C. (it has a huge VI of 222)
Old August 31st, 2012, 04:26 AM
Sandy's Avatar
Sandy
Derrick Wardhaugh
1990 Defender 110, Military spec.
Hi Guys, I have a 110 pick-up that also has the 'crunchy' problem. What puzzles me is that it is an intermittent fault, mostly crunches, but sometimes not?
My issue is i live and work in an area that only has deep sand. A suggestion was made to live with it, or to work with it. Unfortunately by the time I've waited a couple of seconds between shifts,I've come to a stand still. It just seams wrong to let it continue to crunch like that. The motor and clutch have only done 6200km since it was redone.
Any suggestions for the confused newbie?
Old August 31st, 2012, 06:00 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
High range or only in low range ?
If you are only beating the synchro's in low range, the fluid used can make a difference.
I've tried these different fluids and variations thereof (MTF94, ATF (Castrol Transmax Z/NEO 7wt blend), Castrol Syntrans 75W-85, RL MTL (baulky on the upshift) RL MTL/MT90 3/2, Castrol VMX (bloody awful) Torco RTF, Motul Gear 300) and the Gear 300 is the only fluid that has stopped the crunch in all gears in low range and eliminated it high range.
Even Syntrans would occasionally beat 3rd in high range and I pretty much always beat second and third in low range.
Never had a problem with 2nd in high range, ever.
The gearbox has about 295,000km on it.
Old August 31st, 2012, 06:45 AM
Sandy's Avatar
Sandy
Derrick Wardhaugh
tdi-rick. Thanks for that. I will try to get an equivalent locally.
I got under her this morning to see if there my be any loose linkages or something and found the transfer case with a severe case of the runs, checked the level and she was on the low side. Could a badly leaking TC cause this?
Old August 31st, 2012, 07:46 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
No.
They are separate compartments when running an LT230 t/case.
Just quickly, which 'box is in yours ?
The LT77 or the R380 ?
Can't remember what type of gear for the pump is used in the LT77.
If steel, any of those fluids I've listed are fine, if fibre, I wouldn't go heavier than MTL.
Old August 31st, 2012, 01:06 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Same with me, I used Amsoil's Manual Trans fluid and that difference alone made it much more tolerable.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old August 31st, 2012, 02:21 PM
Sandy's Avatar
Sandy
Derrick Wardhaugh
Thanks for the advice guys. I'll change the fluids for now.
I tried all combinations of gear shifts today to see if maybe my habitual change is wrong. What i found is that when i change from 1st to 2nd,(I have a RHD) i come out of 1st then far right and back left right 'against' the left. There seams to be a very slight notch, when pressed left, then directly into 2nd it crunches far less. This however has no effect when engine revs are on the high side.
Sand driving is much trickier than it looks.
------ Follow up post added August 31st, 2012 12:27 PM ------
tdi-rick. I'll check the box type tomorrow and post. I was lucky enough to get the 5 book repair manual with when i bought her. this will help i'm sure.
Old October 15th, 2013, 12:57 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
I've been having issues shifting from 1st to 2nd as well. If I don't wait two or three seconds or double clutch, I grind the gears 90% of the time. I'm running redline MTL also. I take it my only options are to live with it or shell out for some pricey repairs.
Old October 15th, 2013, 10:55 AM
DMSLongLake
Dave Sherwood
1994 D90 ST
Double clutching is cheaper than replacing re gearbox with the added benefit of strengthening your left leg...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
r380
Defender R380 Gear Boxes Rebuilt by the only Land Rover Builder SafariHP The Vendors Loft 3 July 31st, 2012 08:25 PM
Defender R380 Gear Box Cross Member - ANR6386 pabrit For Sale - Parts 5 May 16th, 2012 02:30 PM
R380 with bad 2nd synchro evilfij For Sale - Parts 26 February 25th, 2010 03:56 PM
R380 Transmission Gear Box FS NashvilleRover For Sale - Parts 10 September 14th, 2008 11:52 AM
