R380 hard to shift into reverse - Defender Source
Old November 6th, 2011, 07:12 PM
tommyd's Avatar
tommyd
Tom
LR3
I have a really hard time shifting my R380 into reverse. I have to muscle the shifter into position after 3 or 4 tries to get it into gear.
Any thoughts or suggestions?
Thanks.
Old November 6th, 2011, 07:30 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Put it in 1st and then reverse. Seems to line things up abit.
Old November 7th, 2011, 09:02 AM
tommyd's Avatar
tommyd
Tom
LR3
thanks Jake, I'll try it.
Old November 7th, 2011, 11:56 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Unscrew the reverse switch a couple turns and see if it becomes easier. You may need to insert in a crush washer or two to get the correct clearance if this resolves it for you.
Old November 8th, 2011, 08:19 AM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
I had a similar problem and this was the cause/solution.
Do a search on "u shaped shift quadrant". This will take you to a thread that walks you through how to tighten the assembly.
Old November 8th, 2011, 08:43 AM
tommyd's Avatar
tommyd
Tom
LR3
reverse switch? could you elaborate? sorry, I'm a total noob (but am trying to learn).
------ Follow up post added November 8th, 2011 06:00 AM ------
Thanks Chris. Sounds like this may be the problem. How difficult was this to do? Did you have to take the transmission out, or were you able to fix it as Rob describes in the last post of the thread:
http://www.defendersource.com/forum/...shift+quadrant
Old November 8th, 2011, 09:15 AM
Chris Vitale
Not difficult. It's just a very tight space to work in. I fixed it without dropping tranny. Took a couple of hours.
Old November 14th, 2011, 10:15 AM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
need more details about fixing reverse
can you, guys, specify, which bolt I supposed to tighten?
And where is a reverse switch on this picture.
ID:	43680   Click image for larger version
Old November 14th, 2011, 10:40 PM
Chris Vitale
Ok. Nice.
The u shaped fork should have a screw on the side of it...that screw should set into the shift rod. I recommend stuffing the transmission with a rag or paper towels before you try to remove the screw, so the screw doesn't fall in. You will need to remove the screw so that you can add blue loctite before resetting the screw. And that should do it. Reassemble.
r380
R380 reverse switch Overlander Defender Technical Discussions 6 February 15th, 2010 11:18 PM
Shift knob for R380 61rover For Sale - Parts 2 September 19th, 2009 11:08 PM
R380 Transmission Shift Lever Needed e90miller Wanted 1 August 17th, 2009 11:30 AM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
Hard to get into reverse Troys Defender Technical Discussions 4 January 11th, 2004 01:32 PM
» Defender Registry
Bess
Yorkie
Camel
Camel 422
Add your Defender
