R380 Fluid - Defender Source
Old April 6th, 2012, 06:37 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
R380 Fluid
I am planning on changing the fluid in my R380. i ordered amsoil and I just opened the box to find amsoil manual synchromesh transmission fluid and ATF synthetic automatic transmission fluid... Are they inter-changeable? Or did they make a mistake with the order? Thanks for the help
Old April 7th, 2012, 12:31 AM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
They are very different and not interchangeable. one is for manual transmissions and the other is for automatics. There are many posts on the best choice for RT380 MTF. This can be a finicky transmission and the right fluid is key - even the brand.
Redline is my choice.
"I think you need a little weatherstripping - right here..."
Old April 7th, 2012, 12:40 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I've used reline and royal purple syncormax over the years and both work great. I'd stick with those.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 7th, 2012, 08:49 AM
Grover's Avatar
Grover
Redline from Jegs
Old April 7th, 2012, 05:13 PM
Redline MTL
Old April 7th, 2012, 05:37 PM
I put redline MTL in mine and I'm amazed at the improvement over whatever was in there before. My 2nd gear synchro is very weak but noticeably better after the redline. Wasn't cheap ... But used summit for fast delivery.
Old April 9th, 2012, 08:32 PM
Rufus's Avatar
Rufus
Rufus
Thanks i thought they werent interchangeable and wanted to confirm.
Old October 27th, 2012, 02:41 PM
Lrd90
Anthony
95 Defender 90 (SOLD)
which Redline MTL 85 0r 90? Thanks
Old October 27th, 2012, 08:51 PM
There is only one and it is 70W80. http://www.redlineoil.com/product.aspx?pid=45&pcid=7
Old October 28th, 2012, 09:07 AM
Redline mtl
Old October 28th, 2012, 09:10 AM
$15 with Amazon Prime:
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Old October 28th, 2012, 11:58 AM
61rover's Avatar
61rover
John Crouse
x10 on Redline MTL.
Old October 28th, 2012, 09:50 PM
Lrd90
Anthony
Thanks for all of the advice....bought 6 qt MTL from Amazon.
Old October 28th, 2012, 10:02 PM
6? You stocking up? Keep in mind this does NOT go in diffs or tcase. Just tranny.
Old October 28th, 2012, 10:05 PM
Lrd90
Anthony
it take 2-3 qt?
Old October 28th, 2012, 10:34 PM
Ray_G's Avatar
Ray_G
Ray Gerber
~2.8qts I believe.
r380
Best fluid for the R380? oldscratchggf Defender Technical Discussions 9 April 7th, 2006 09:02 AM
Gear fluid ..... Rover- Girl Defender Technical Discussions 3 October 9th, 2005 05:25 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
» Defender Registry
Hank
D110
Series III
kraison
Add your Defender
