R380 Fitment question - Defender Source
Old September 12th, 2007, 05:04 PM
Cirbo's Avatar
Cirbo
Jim C.
Greetings,
I have a chance to get my hands on an R-380 from an ex-military defender 110. The truck came equipped with a 2.5 NA Diesel. What applications can this transmission be used for? Would it work for a 2.25? 200tdi? etc....
TIA,
Jim
Old September 12th, 2007, 06:52 PM
Doesn't the 2.5 use the same length input shaft as the v8?
Old September 12th, 2007, 09:26 PM
pendy's Avatar
pendy
jim pendleton
89'd90
No
Are you sure it is a R380?
It would be a rare one if it was. That is the trans everyone wants to use to put a 300 tdi in a 88" series.
JP
legend in my own mind
Old September 12th, 2007, 10:27 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by Cirbo
Greetings,
TIA,
Jim
Well, it will work with a 300 Tdi, don't know about the 200 Tdi, not sure.
- Charles Eames
Old September 13th, 2007, 10:02 AM
LRover's Avatar
LRover
J. Michael McCaig
2.25, 2.5 and 200TDI all had the same bellhousing bolt pattern. Most commonly it was a LT77 behind the 2.5 so check where reverse is.
Old September 13th, 2007, 10:15 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Ashcroft should know, I would ask them.
Old September 13th, 2007, 10:30 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
Later MOD 110's did in fact come with an R380 mated to the 2.5 NA diesel. I am driving one myself. The bell housing on this gearbox is shorter allowing the 2.5 to sit farther back in the engine compartment.
If you want to mate this gearbox to a 200Tdi, you would need to swap the clutch housing from the 2.5 NA the gearbox was originally attached too onto the Tdi. Not sure if this is doable with the 2.25 diesel.
I am about to but a 300Tdi into my 110 but have decided instead of mucking about with trying to install the engine in the rearward position (because of the shorter bell housing), I have found an R380 with the longer bell housing. Should make the install much simpler.
I am thinking of putting the 2.5 NA and R380 out of the 110 into my Series 3 88.
Brett
r380
R380 Transmission Input Shaft Bearing Question Heath Defender Technical Discussions 0 March 15th, 2007 03:09 PM
110 tire fitment question evilfij Defender Technical Discussions 12 January 31st, 2007 09:22 PM
r380 diesel/v8 question D90user Defender Technical Discussions 5 January 1st, 2006 07:15 PM
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
