r380 diesel/v8 question - Defender Source
Old December 20th, 2005, 02:48 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
is there a difference in a r380 for a diesel and a V8? I know the bell housing is different but what about the center shaft?
Old December 20th, 2005, 03:48 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Steve,
Yes, The input shaft is a slightly different length and the end that goes into the pilot bushing is bigger.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 20th, 2005, 05:44 PM
D90user's Avatar
D90user
steve
Rob,
Thanks for your reply.
Can you just use the input shaft for a 300tdi in a r380 V8 or is it more complicated than that?
Do you have any 300tdi input shafts sitting around??
thanks
Steve
Old December 20th, 2005, 06:00 PM
Roadsiderob
Robert Dassler
1994 D90
Steve,
Yes, an R380 for a V8 can be converted to 300Tdi by changing the input shaft. It will be necessary to check and adjust the bearing preloads after swapping the input shaft. This will require completely dismantling the transmission. I have a 300Tdi R380 core out of a Discovery, however, I have not dismantled it to check the condition of the input shaft. It is completely locked up, so there's no guarantee it's good. I can strip that box down if you'd like and see if the shaft is still good or I can get a new input shaft pretty readily from the UK if you require it. Call me at the shop if you can.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 26th, 2005, 01:48 PM
I have an entire 300Tdi R380 which is surplus to my needs.
evilfij at yahoo dot com
Old January 1st, 2006, 07:15 PM
JSQ's Avatar
JSQ
Jack Quinlan
Ron,
does that mate up to a 2.5NA?
diesel, r380, v8
R380 Fitment question Cirbo Defender Technical Discussions 6 September 13th, 2007 10:30 PM
R380 Transmission Input Shaft Bearing Question Heath Defender Technical Discussions 0 March 15th, 2007 03:09 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
