R380 - Cannot remove extension housing - Defender Source
Old March 4th, 2015, 10:20 AM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
I am using the R380 Overhaul manual and I have done the following but the extension housing will not separate fully.
1. Remote shift housing removed
2. Reverse/5th gear selector spool retainer removed
3. Extension casing bolts removed
4. Pulled oil seal collar from output shaft
5. Use a soft faced mallet to tap (ha ha) extension free from locating dowels
I get a couple centimeters of separation but not much more. Anything I missing to get this thing separated? I am assuming I need to give it more than a tap to separate....but how much more? And did I miss anything that would keep this from coming apart?
ID:	115191   Click image for larger version
ID:	115193   Click image for larger version
"I think we are good...its still dripping"
Old March 4th, 2015, 10:59 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Derek I have an Idea. I will be right over to help separate.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old March 4th, 2015, 11:19 AM
WildBoar's Avatar
WildBoar
Derek Borror
Ah....must deploy a BFH!
Definitely the next step if there is nothing but friction holding it together.
Old March 4th, 2015, 01:25 PM
WildBoar's Avatar
WildBoar
Derek Borror
BFH deployment successful.
As suspected layshaft is in 2 pieces.
ID:	115233   Click image for larger version
r380
Damn! Cannot figure out what is wrong with the lights! solihul Defender Technical Discussions 11 October 26th, 2017 07:04 PM
LT230 extension housing swap red64chevelle Defender Technical Discussions 8 October 16th, 2011 09:09 AM
Wired.com article, "you cannot have these cars" hillstrubl Misc. Chit-Chat 0 April 11th, 2011 10:10 AM
How to remove channel to remove seat skins Campbell Defender Technical Discussions 2 October 23rd, 2009 05:47 PM
Cannot UPLOAD PHOTOS: norros Support & Suggestions 12 October 6th, 2005 08:25 PM
