R380 -> 200TDI caveats? - Defender Source
Old February 18th, 2009, 01:03 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Are there any other changes needed to fit a 200TDI with an R380? Do I need to modify the bulkhead, seatbox, or the tunnel covers between them? I get my welded bulkhead back in a couple days and before it goes for galvanizing I wanted to make sure.
Thanks.
Old February 18th, 2009, 02:18 PM
paulnb57
Paul Beckwith
92 D90 300tdi hard top rebuild
Im guessing you are converting from V8 petrol to 200tdi??
If I remember right the trans tunnel and the "diaphram" bracket on the bulkhead that the front of the trans tunnel fits to are different. Using the correct tunnel also provides the hole for the gear and hi/lo CDL sticks/rubber trim. Also I think they are all bolt on. This made it easy for LR to fit different engine/gearbox combinations and use the same bulkhead/floors/seatbox.
This link shows the diaphram (td5) bracket in case you're not sure what I mean
http://cgi.ebay.co.uk/Defender-Td5-g...1%7C240%3A1318
Good luck!
Paul
edit
But then again, if you are converting a 200tdi from Lt 77 to R380 Im not sure - hopefully someone with a parts manual will be able to check if the diaphram/tunnel have the same part numbers between the 2 gearboxes..............was Lt77 - 200tdi and R380 - 300tdi??
edit x2
bit more digging on ebay shows a trans tunnel to be the same for V8/300tdi/td5
http://cgi.ebay.co.uk/LAND-ROVER-DEF...1%7C240%3A1318
I also seem to remember the 200tdi is alloy whereas the V8/300/td5 is moulded plastic...........
Ede Bibe Lude Post mortem nulla voluptas.
Eat Drink Play, After death there is no pleasure.
Old February 18th, 2009, 02:29 PM
ajh
Andrew J. Hutton
No, from 200TDI with LT77 to 200TDI with R380, I'm also going to do a chassis swap and hopefully getting both mounting locations prepared for the current 200TDI and a future possible IS2.8TGV if I go that route.
Yes, it changed some time in 1993. If I can get the 200TDI with the R380 to be rock solid I'll just put in a VVT and big intercooler and leave it at that, it would be my long-term preference anyway.
200tdi, r380, tdi
LT77 crapped out on 200Tdi - swap in R380 ? metric Defender Technical Discussions 8 June 11th, 2008 11:58 PM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
r380 diesel/v8 question D90user Defender Technical Discussions 5 January 1st, 2006 07:15 PM
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
» Defender Registry
White
KGH
My Baby
Seiders
Add your Defender
