R&P: how to check? - Defender Source
Old December 7th, 2006, 03:16 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
R&P: how to check?
If you have in front of you a ring and pinion.... How can you tell that they are in good shape to be re-installed? Actually.... Is that even possible or do you need to re-install them on the carrier/differential?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 7th, 2006, 03:21 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
As long as there is no chunks missing or super obvious funky wear, you could use them. Whether they would be quiet or not, who knows until you check a pattern with them installed.
Old December 7th, 2006, 03:46 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
post a pic....
Old December 7th, 2006, 04:44 PM
MonLand
Loic Fabro
Here is a pic.
Seems to be in good shape.... But I honestly don't know where to look....
Name:	Ring & P smaller.JPG
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 7th, 2006, 10:31 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The pic would have to be much higher quality to actually check. The general rule for a rover R+P is, if it is not missing teeth, count your blessing and re-use.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 8th, 2006, 03:25 AM
ashtrans
Dave Ashcroft
I would go with this, if they look OK, we :
'dress' them ie run a die grinder over each side of every tooth to remove high spots on both gears
assemble with original pinion height shims,
set pinion pre load,
put in diff centre, set backlash and preload
oil it and 'roll' it a few times, if it feels quiet, well done, if not blue it, check the contact patch and adjust accordingly, try adjusting a few times but if it had been running either badly set before or with worn bearings then no amount of adjustment will get it quiet and it goes in the scrap, grab a new R & P and start again,
Dave Ashcroft
Old December 8th, 2006, 09:53 AM
MonLand
Loic Fabro
I am planning on using it to setup my ARB locker before I actually dismantle the 3rd member (i.e. the truck will be useable for longer! :-) ). So, I'll also get new bearings.
Is it recommended to keep the pinion that matches with the ring? (I assume it is for even wear reasons?)
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 8th, 2006, 09:58 AM
ashtrans
Dave Ashcroft
"Is it recommended to keep the pinion that matches with the ring? (I assume it is for even wear reasons?)"
definatly, they are match machined, mixing is a recipe for noisy diffs,
Dave Ashcroft
Old December 8th, 2006, 03:24 PM
MonLand
Loic Fabro
I posted that same picture in higher resolution at: https://d90rox.kicks-ass.org/ringand...ng%20&%20P.jpg It could use a better contrast/luminosity/.... But unfortunately, this computer has no image manipulation tool installed! :-(
MonLand
1995 D90 NAS
1996 Discovery NAS
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
