Quieting a 300 Tdi - QuietCar coatings - Defender Source
Old July 8th, 2007, 08:57 PM
cdb
Clark Bowen
I wrote earlier that i was going to try QuietCar on the bonnet underside to quiet the 300 Td.i After much hesitation (it was newly painted and pristine) I finally did. It goes on very easily, with minimal overspray and takes about 7 days to cure. I used 1/2 gallon ($58 per gallon) and it added about 5 pounds to the bonnet weight. The bonnet definitely feels more substantial now and I think it did help quiet the underhood noises but the biggest improvements came from the thick rubber firewall pads and floor mats that RN sells. Only drawback is that they need some help staying up in hot weather. They simply buckle and fall on your toes unless you anchor them some way. Also a Magnaflow flow-through muffler took the sharpest rap out of the exhaust and with no loss of power.
I think the QuietCar helps and would be excellent sprayed on the inside of the doors where you would put DynaMat. It is black and looks a lot like Line-X or Rhino coatings. I've used Dynamat on the doors before which helped the output from the door speakers substantially and the doors then close with a satisfying "thunk".
If I could find a good sound absorbent material to glue to the Quietcar I think I would be doing about all I could to quiet the D90. Any ideas?
Clark
Old July 9th, 2007, 10:26 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have always dyna mated my doors. IT is a great improvement just on shutting the doors alone. IT makes them feel so much better and I'm sure helps with some noise. I want to do under the bonnet next.
Legend in My Own Mind.
Old July 9th, 2007, 12:14 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
LizardSkin
Hey - I have some Diesel Unimog friends who've used lizardskin with good results - spray on and forget...
http://www.lizardskin.com/index.php
Henry
www.4x4freedom.com
Old July 9th, 2007, 07:46 PM
cdb
Clark Bowen
QuietCar
On the LizardSkin
Looks similar to and the description sounds like QuietCar. It seem to me a much better process than cutting and sticking Dynamat to surfaces.
I will spray my doors eventually too.
Clark
300 tdi, tdi
300 tdi lrnasd90 Wanted 2 July 29th, 2005 06:55 PM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
