Quickest way to change a brake booster? - Defender Source
Old May 13th, 2009, 05:18 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I need to change the brake booster on a 95 D90. Is it quicker to remove the six bolts holding the brake assembly and lift it out or try and pull the pin connecting the booster to the pedal assembly and do the booster by itself? I'm waiting fot the vehicle to return from a little painting, but want to do this as quickly as possible and think the clutch hardware may be in my way when I trying to get to the pin.
Old May 13th, 2009, 08:29 PM
When I tried, I was not able to get the pin out successfully with it in situ. Maybe you will have better luck.
boost, brake
brake booster? tomaco1 Defender Technical Discussions 3 October 2nd, 2009 04:15 PM
cracked brake booster: interchange? jaherring Defender Technical Discussions 4 November 29th, 2007 08:33 PM
Brake Servo / Booster -- Any Interest For cheap group buy??? Heath For Sale - Parts 6 August 12th, 2006 07:05 AM
About to change brake pads whitelandy33 Defender Technical Discussions 13 December 19th, 2003 01:57 PM
