Quick way to match Apline White? - Defender Source
Old July 22nd, 2015, 08:56 AM
Question Quick way to match Apline White?
Master cylinder appears to have crapped out on my 1994 NAS 90 (again...only lasted about 20k miles!). Anyhow, the dot4 obviously does not react well with paint...and took some off the footwells (inside and out).
As such, normally I don't pull the wing to do the clutch master...but in this case I'm going to since I need to do some touch up.
Anyhow this brings me to my question - anyone find or have a good match for Alpine White that is readily available (ie hardware store, auto parts store, etc)? I have color matched paint in cans at home, but alas I'm not home and the custom paint matching places typically say 3-5 days + shipping time....but I can't have the truck down for a week or more.
Input appreciated if anyone found any *close* Alpine White matches.
Old July 22nd, 2015, 10:14 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I have used Krylon dover white in gloss and worked out ok.... not perfect but should be ok for where you are painting... good luck...
good luck with your search
Old July 22nd, 2015, 10:35 AM
Thanks Ron! I'll give it a shot...pulling wing today and cleaning/priming, oh what fun...
Old July 22nd, 2015, 12:05 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Is there a NCS near you? They should have a color match there that they can put in a aerosol can for you.
Old July 22nd, 2015, 01:10 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
NCS? humor me...
Old July 22nd, 2015, 01:44 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
National Coating Supply, our paint and body supply company. Our local one will paint match/take pictures of paint to match along with aerosol if time permits.
Old July 22nd, 2015, 04:20 PM
No NCS, but actually just found a place called Keystone that looks like they can match Alpine White from the paint code (LRC456/NUC or the PPG cross-ref 90991...looks to be Alpine/Saverine White) and have it ready tomorrow. Going to give it a shot, as where I'm painting literally will never be seen anyhow.
Old July 22nd, 2015, 08:08 PM
87 D110 (Ruby)
Jason if you have the paint code APS towers paint will match perfectly Ina great spray can. I have used them for all 6 restos I did and just ordered 4 cans for the new galvy doors on the 110
Old July 22nd, 2015, 08:14 PM
My main issue is time constraints...truck is pulled apart for a new clutch master (because the sh*t doesn't last more than 3yrs/20k miles!). It was primed today, and looking to topcoat tomorrow.
The kicker is I have 2 cans of Alpine White sitting in my garage at home that I had made up awhile ago...
Old July 22nd, 2015, 08:27 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Good luck, looking forward to seeing how it works for you.
Old July 22nd, 2015, 08:28 PM
Remind me to check the basement but I think I have a can of alpine white you can have as well. I know that doesn't help you right now though.
Originally Posted by pendy
I'm here for the D's
Old July 22nd, 2015, 08:45 PM
87 D110 (Ruby)
Not like you are entering the damn thing in a beauty contest! Prime it. Wait till you get back here in September.
chuckc4
chuck b
Registered User
LAV, I have a quart of it mixed up in my basement -- don't know if that helps as it will require spray eqpt. I am about an hour south of you right now.
I sent you a PM with my #
chuck
Old July 22nd, 2015, 09:00 PM
Somewhat unrelated, but what brake fluid are you using?
Old July 22nd, 2015, 09:01 PM
It's the bulkhead footwell that's INSIDE of the engine compartment...already pulled the entire fender skin to access/etc. The goal here is not to win a beauty contest (as I like to bash up my truck), but rather to continue keeping rust at bay. I mean...you can eat dinner off my bulkhead!
Anyhow....picking up the can from Keystone Autobody tomorrow morning so *should* be all set.
Old July 22nd, 2015, 09:05 PM
Castrol Dot4 (GT LMA since I'm still hoarding a few bottles of it). However, I sincerely want to consider moving to a silicone-based Dot5 after this recent BS. Speaking of which - has anyone run that in the clutch and/or braking system on a Defender?
Old July 22nd, 2015, 09:18 PM
As far as I know, Castrol LMA is not an ISO 4925 Class 6 fluid, therefore not the same as the Land Rover brake fluid. I think the Castrol is only a class 4 which is not a low viscosity brake fluid. I would recommend Pentosin DOT4 LV.
Old July 22nd, 2015, 09:21 PM
Available for purchase at the dealer? Or are there other alternate locations it is available?
Old July 22nd, 2015, 09:33 PM
Briggs may have talked me into trying this swap:
Slave cylinder retrofit. Series and pre-puma defender. - Expedition Portal
Old July 22nd, 2015, 09:49 PM
Land Rover Genuine brake fluid is backordered at the moment due to an upcoming recall on the front brake hoses of L322 Range Rovers. We have been getting the Pentosin fluid from a local store at the dealership. It is worth noting that the Pentosin website says that their regular DOT 4 brake fluid is correct for Land Rovers, but that is actually not true if you look at the Land Rover spec. It needs to be a low viscosity brake fluid.
Powder Coat Match to Alpine White d110pickup Defender Technical Discussions 8 January 21st, 2015 01:12 PM
97 D90 Built WAY WAY Less than low book mightymg For Sale - Vehicles 11 June 6th, 2013 08:42 PM
Apline windows evilfij For Sale - Parts 2 April 13th, 2009 08:34 PM
Contura Switch 3 way and 2 way Rugbier Defender Technical Discussions 21 January 26th, 2009 11:45 PM
Quick question, softtop bar clips face which way? btate Defender Technical Discussions 13 November 19th, 2008 03:42 PM
