Quick Steering Fix - play in the steering wheel. - Defender Source
Old February 23rd, 2012, 08:35 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Just a FYI - I'm sure this is old news, but I had about 4-5" of play in my steering wheel before the wheels actually moved. Tighted up the allen screw (after loosening the jam nut), about 3-4 turns and it took all the play out. 100x better.
Just incase anyone has this issue and isn't aware of a way to fix it.
I'll probably need a new box down the road (mines a bit leaky) but for now its good
Old February 23rd, 2012, 08:38 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I had this problem once, turned out the pitman arm was moving up and down from the nut comming loose.
Robert Deniro
Old February 23rd, 2012, 08:51 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Where is the allen key and lock nut?
Old February 23rd, 2012, 09:01 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Follow the steering linkage to the steering box. On the top of the box there is a allen key with a jam nut around it. Litterally on the top of the box.
Loosen the jam nut, tighten the allen key until any play in the linkage is gone, then tighten up the jam nut. Dont overtighten the allen key otherwise you steering will be impaired (too tight).
Old February 23rd, 2012, 10:38 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Nice you got that sorted out - 4-5" of play would have drove me crazy!
Old February 27th, 2012, 08:37 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Here's a good link on how to adjust the box: http://www.rangerovers.net/repairdet...oxclassic.html
I've just gone through the same thing with my DII.
wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
