quick question: wiring - Defender Source
Old September 11th, 2013, 02:48 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
This wire runs into the passenger side of the frame where the middle crossmember is.
1) Where does it terminate? Is it running further down the frame or across and inside the crossmember?
2) What wire is it? Positive lead, sensor wiring, etc?
Old September 11th, 2013, 08:51 PM
CaptMidnite
Daniel Choi
anyone?
? ? It's a 94 D90 BTW.
Old September 11th, 2013, 09:06 PM
Zoom out. Hard to tell. Probably the rear lights though.
Old September 12th, 2013, 08:29 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You will have the chassis harness that runs inside the frame and exits at the rear before the cross member. However your wire is on the outside next to a frame horn? Where does it come from, the bulkhead?
Old September 12th, 2013, 11:31 AM
CaptMidnite
Daniel Choi
Ah, it's all making sense to me. Yes, the wire runs from the bulkhead, splits off into a "Y" with one end going into the transmission area (rear backup light switch?) and other runs into the hole in the frame.
I also have a random wire that starts at the bulkhead (see pix- no continuity or voltage readings), and runs into the same black wire loom casing as the harness that eventually splits and runs into the frame.
Been pulling a lot of strange wiring left by the PO.
Old September 12th, 2013, 11:37 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
The loom in the first picture is your chassis harness, which runs all the way to the rear of the chassis and exits between the upper spring perch and the crossmember. It contains all of the wires that run your brake, tail, indicator, tag and reverse lights. It may also contain a wire for the heated rear glass and speaker wiring if your truck has either.
Old September 12th, 2013, 03:06 PM
Capt Milks's Avatar
Capt Milks
That looks like a factory wire. What colors are they?
wiring
« Hose blows | P1317 »
Trailer wiring question.. DonFromWhitby Defender Technical Discussions 23 June 30th, 2013 10:37 AM
Front wing - turn signal wiring / routing question nathanwind Defender Technical Discussions 3 December 23rd, 2012 08:18 AM
Custom wiring question Doug Defender Technical Discussions 7 December 15th, 2004 02:43 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Winch wiring question flippedrover Defender Technical Discussions 4 January 11th, 2004 09:20 PM
