Quick question, softtop bar clips face which way? - Defender Source
Old September 25th, 2006, 05:55 PM
btate
Bryan Tate
d90
My truck had no softop bar for the tailgate. I picked one up from a member with the plastic clips.
I would think the hollow portion of the plastic clips would face inward/forward, but I could see if facing the other way also.
Anyway, before I take the speakers out and drill/punch thru the Rhino lining I wanted to make sure I had the orientation correct.
Old September 25th, 2006, 06:19 PM
GYM's Avatar
GYM
Gary
97 SW
Look in Tech section on this site - Soft Top install. Pg 5 of 16 shows clip install.
Old September 25th, 2006, 06:33 PM
btate
Bryan Tate
d90
Did a search didn't pop up
Old September 25th, 2006, 07:16 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Inwards facing. Once in, look at any gap, go to hardward store, buy weathering strip
Old September 25th, 2006, 09:24 PM
1) It takes no extra weatherstripping to make a ST seal up fine.
2) The open part of the clip faces rearward, so that the bar snaps in from the rear. It snaps in quite positively and you have to open the door and smack it from the inside to pop it off. Once you slide the bar onto the rear window you'll see that the channel faces forward and only really leaves the possibility to install the clips facing rearward.
Old September 27th, 2006, 11:34 PM
paulb's Avatar
paulb
Paul / Boultbee
Jim, what do you have there on your 95? I run a 1/2 inch strip to cover the gap the between the tail gate top and the bar at the rear window. Mine does not seal up fine - but it is an old top and I am just used to it. As to point 2, interesting. I clip mine in reverse from your description. Looking at the bar, it seems to makes no diff. Just an interesting varient on D-90 set up?
Now if I could only fix the rivers that enter my truck when the fast back is on it - see avatar.
Old September 28th, 2006, 12:01 AM
Is the rubber seal still present on your tailgate bar? The seal on mine fills the space nicely. I notice it slides out easily, so it could conceivably be lost.
I'm not even sure how you insert the bar to make it fit if you install the clips backwards. I'd go check it out but my wife just had a baby...
Old September 28th, 2006, 12:30 AM
paulb's Avatar
paulb
Paul / Boultbee
Good god man, where are your priorities! A baby grows towards independance at age 18 (well legally) while a Land Rover grows away from independance at approximately the same rate so by 18 yrs old it needs a lot more loving care. Trust me, the baby will be there and Mom will let you pretend to help. The LR needs you now and Mom will not help! So go look; do not miss the small moments, like which way a clip faces, cause once gone, they are lost forever.
Old September 28th, 2006, 09:03 AM
themaxx's Avatar
themaxx
Ade
94 ST
Cats in the cradle...
Old September 28th, 2006, 10:47 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I just got a BIII and the rubber peice doesn't sit flush with the rear tailgate. It clips in just fine but there is still a gap.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old November 18th, 2008, 07:27 PM
jordan0527's Avatar
jordan0527
Jordan
97 D90 ST, 04 D2
I just installed my soft top for the first time in a couple years, and for the life of me can't get the bar in the rear window to snap into the clips securly. It will kind on "angle" onto the clips and hold for a moment, but as soon as I hit a small bump in the road it pops out. It just doesn't want to stay clipped in. Anyone know what I'm doing wrong?
Old November 19th, 2008, 02:56 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
On mine the left side fits in easily but the right side has to be hit hard to get it to snap into place. When it finally engages you can hear a pop. It sounds as if your plastic retainer piece is worn out or you are not getting it seated totaly in place.
Old November 19th, 2008, 03:08 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
My Badger 2 has a large gap as well.
Old November 19th, 2008, 03:42 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I know the original Tickford tops shrunk over time and left a large gap (1"-2") between the tailgate and the rear window. I never bothered correcting mine though because it doesn't get that cold here and my dog liked to stick his nose out the back.
ac, clips
Tailgate bar for softtop, new, no clips evilfij For Sale - Parts 4 August 11th, 2009 07:29 PM
The two clips that the rear tailgate bar snaps onto and vertical rods for softtop evilfij Wanted 7 February 23rd, 2009 03:27 PM
roll bar question tim Defender Technical Discussions 4 June 18th, 2005 10:34 PM
Header bar, yellow hinges, tailgate bar clips mspell Wanted 1 October 4th, 2004 04:20 PM
Fabritech Sway Bar Quick Release Kit For Disco Series 1 kpracer For Sale - Parts 0 July 22nd, 2004 01:50 AM
