Quick question on rear spring diameters - Defender Source
Old March 21st, 2012, 12:38 PM
BlackField's Avatar
BlackField
Oscar
D110
hello,
Anyone know if the inner diameter of the rear springs is the same between a 1985 110 and a 1997 90? That could help me out on my search for helper springs or helper airbags. 99% sure its a Salisbury but I'm not in the same state as the truck to double check.
Oscar
Old March 21st, 2012, 01:00 PM
They are not. The 110 inner diameter is bigger.
Old March 21st, 2012, 02:02 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
The 110 inner "helper" springs are quite a lot smaller (in diameter) than a 90 spring.
I've got a set on my 110... want me to measure them?
Old March 21st, 2012, 02:36 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Originally Posted by BlackField View Post
hello,
Oscar
WHy not get the right springs? Like ROn said, the 110 springs are wider than the 90 springs.
John C.
Old March 21st, 2012, 03:48 PM
BlackField's Avatar
BlackField
Oscar
D110
I don't really follow your question. I have a 110 with, what I assume to be, OEM 110 springs. But I think I might be confusing the situation.
Let me rephrase my question.
I have a 110. I would like to order a helper airbag set up, but the only airbags I am finding are for D90s. So I hoped that they were the same size. Evilfij thanks for the info I guess considering the likely weight rating difference it would make sense that the 110 would be a larger spring.
Diesel Jim, if you could let me know where you found the helper springs that would be cool.
I tend to tow and have a bike mototote hitch mounted bike hauler when I only lug one bike around. The air bags and helper springs usually do the trick. Although with that crazy center mounter shock thing under the 110 it may not be needed, but Im not even sure if that thing is still doing its job.
Here is a pic of the D1 that led me to buy springs or bags on subsequent LRs.
Old March 21st, 2012, 04:01 PM
JohnC
I also have a bike hauler for my bike but my rear springs are rated to carry the extra load, get some rear springs to handle the load.
John C.
Old March 21st, 2012, 04:06 PM
110 and 130 Rear springs are 7" outside diameter.
All other classic LR coil springs are 6" OD.
Inside diameter varies with the coil used.
Old March 21st, 2012, 07:33 PM
JohnC
I have a set of rear D110 springs and the Firestone Air bags, if I get a chance tomorrow I'll take some pics.
John C.
Old March 21st, 2012, 07:42 PM
BlackField's Avatar
BlackField
Oscar
D110
Score thanks!
Old March 21st, 2012, 11:15 PM
Aren't 130 rear springs a sort of double spring inner/outer setup?
Old March 22nd, 2012, 01:20 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
some are... only the HD setup, some 130's just have a single spring a la 110. (and some 110's have the win spring setup for HD.... or maybe XHD? although mine doesn't seem too stiff, they're quite progressive.)
Rear Spring seat wedges? KevinNY Defender Technical Discussions 21 July 13th, 2011 08:22 PM
Dingbat question on rear NAS bumper fitting smob Defender Technical Discussions 11 April 22nd, 2011 03:48 PM
Another rear bumper question TexasD-90 Defender Technical Discussions 26 December 31st, 2010 08:52 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
