Quick question, let's say you lose the rear brake line on a D90, is it dual circuit? - Defender Source
Old July 20th, 2009, 03:02 PM
Are the front and back brakes on seperate circuits so that it will still stop or no? I want to say that on a disco I it is LF/RR and RF/LR on seperate circuits.
TYIA for a prompt answer.
Ron
Old July 20th, 2009, 03:10 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
On d90 you have three lines off master cylinder. One right front, one left front and one to rear which T's at axle. D90 or 110 has proportioning valve - can't remember which, but I think it's 110?
Old July 20th, 2009, 03:22 PM
Sorry, it is a 110 not a D90. It has a proportioning valve. If I lose brakes aft of the proportioning valve, it should still have front brakes right.
Ron
Old July 20th, 2009, 03:29 PM
it is a two circuit system so yes you wlll have some brakes. but there is no shuttle valve to stop the fluid to the compromised circuit.
Old July 20th, 2009, 03:37 PM
So, if I top it up it should be ok until it leaks out again? I just need to move the thing half a mile.
Ron
Old July 20th, 2009, 03:42 PM
sure. you will know if it is really bad. the reservoir is divided so it shouldn't all leak out anyway. the pedal will be low.
Ron
Old July 20th, 2009, 03:49 PM
TY,
I am betting some series style pumping will be sufficient to make it stop.
Ron
Old July 20th, 2009, 04:08 PM
Does not run. No hand brake. I drove my series truck without brakes for a while, but I had the motor running to slow it down.
I am thinking about leaving it in 2nd or so and just letting out the clutch when I want it to stop.
Ron
Old July 21st, 2009, 08:05 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
Ron,
I have been suffering through a brake system replacement on a 1970 italian car over the summer. In case you need to replace the chassis mounted hard lines and connectors, you might want to check out www.fedhillusa.com. They have the largest selection of fittings, bleed valves, that I have ever seen.
90, brake, d90
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
Left rear brake Light Out, and I mean Out! RickM Defender Technical Discussions 6 December 8th, 2004 09:31 PM
question about rear ladder fitting my ride chirider Defender Technical Discussions 1 December 7th, 2004 11:20 AM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 04:59 PM
