Quick Q?: front blinker lights with brake pedal - Defender Source
Old December 11th, 2013, 11:58 AM
BlackField's Avatar
BlackField
Oscar
D110
Is there a brake light path that goes to the front of the truck?
Granted I may have cut one cable too many while removing PO wiring, but I thought it was pretty bizarre when I noticed it this past weekend while moving the truck around.
Oscar
Old December 11th, 2013, 01:20 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Oscar
Not ordinarily!
Something is connected up wrong.
Mike Hammond
Old December 11th, 2013, 01:23 PM
Normally, if you have one light causing another to turn on, it is a ground problem. The power from the ground of one light is powering the other light through it's ground. Check the grounds on all of the lights in question and make sure they are properly connected to the body or chassis.
Old December 11th, 2013, 05:19 PM
mikeslandrover
Mike Hammond
Yes 100% agree if the lights are physically close together and share a ground thats bad to the chassis/bodywork but front to back of the vehicle seems a long way for a bad ground to cause another light to light up.
Oscar does the brake light light as well dimly as well as the front light or is it just the front blinker at full power?
If it's the latter to my mind it's more likely to be incorrectly wired lights than a ground problem.
Mike Hammond
Old December 12th, 2013, 05:14 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The brake light wires are in the chassis loom that is connected at the firewall via a plug. The front wing loom is also connected to a plug at the firewall one for each side. The brake light switch is on top of the brake box on the firewall. Is the flashing light on the same side as the brake light switch?
Old January 11th, 2014, 02:03 PM
BlackField's Avatar
BlackField
Oscar
D110
Thanks for the replies guys. Maybe it has something to do with my rear lights being disconnected? I have everything stripped out for the paint shop and I was so focused on this bizarre front brake light occurrence that I forgot to mention that all my rear lights are disconnected and sitting on a shelf in the garage.
Thanks again, still odd. hopefully it is sorted when I reassemble the truck.
Oscar
Old January 12th, 2014, 10:20 AM
Yep. There have been a few threads recently with people who have had this issue and when I had the issue it was because of the rear lights.
brake, ht, lights
Series 3 Front Brake Hoses mgyip Series Technical Discussions 6 May 16th, 2013 03:55 PM
No brake lights, turn signals, temp or fuel gauge. John T Defender Technical Discussions 1 August 3rd, 2010 12:54 PM
Soft Brake Pedal Issue.... greend90SW Defender Technical Discussions 3 December 29th, 2007 02:25 AM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
