quick OME query - Defender Source
Old November 18th, 2006, 09:34 PM
quick OME query
do OME springs have a top and bottom? Does this matter when installing?
Old November 19th, 2006, 06:53 AM
btate
Bryan Tate
d90
Nope, I've just tried to turn them so they seem less likely to bind or jump over the perches.
But normally there is a passenger/driver side. But from what I recall you reverse that in the US (left hand drive/more weight). But they are hard to get to sit level.
Exped Exch goes to the trouble of opening each box and sending you 2 drivers or 2 passengers to avoid the disparity in height. Even then you may have some lean.
Old November 19th, 2006, 11:53 AM
If it is progressive, technically speaking the tight coils should be on the top. This is reduce unstrung weight......not that there is measurable any difference.
Old November 19th, 2006, 01:37 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I run the tight coils on top because its easy to place the bottom retainer
Old November 20th, 2006, 08:04 AM
OME MD are not up or down as they are straight rate springs. OME HD as said is progressive and has a top and bottom.
OME HD Springs & OME Nitrocharger Shock Set Steve Friedman For Sale - Parts 1 January 24th, 2008 10:11 PM
OME spring settle? kolvedic Defender Technical Discussions 17 October 4th, 2005 08:54 PM
Lr Hd Vs Ome Hd/md mattarm Defender Technical Discussions 5 September 15th, 2005 09:36 AM
OME upgrade advice kolvedic Defender Technical Discussions 11 August 16th, 2005 11:08 PM
OME 751/764 vs. RTE 2" J4hand Defender Technical Discussions 3 October 25th, 2004 06:18 PM
