Quick Nuts - Defender Source
Old August 5th, 2010, 03:58 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Quick Nuts
Have any of you bought the AB quick nuts to make removing your door windows easier? Is it worth the $75?
Is there a McMaster-Carr equivalent for much, much less?
Looks interesting, thought I'd see what the consensus is while I wait for a new starter....
Jerod
Old August 5th, 2010, 04:58 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Am I the only one that thought this tread might be about premature ejaculation??
Couldn't resist.
I bought the AB quick nuts. They are great, no complaints. They are a bit more than you would expect but I don't know of a less expensive option.
Get the SS door studs too.
Old August 5th, 2010, 05:11 PM
I have the RN ones that rust. I really don't see the point to these things but to each his own.
Old August 5th, 2010, 05:34 PM
MikeRuby
Mike Ruby
'95 D90 #2523
I researched to try and find a less expensive option, and after a bunch of time hunting, was able to find some simple steel collars with a nut crimped into each end... they worked fairly well, but rusted horribly in a few weeks... rusted to such an extent that they were a major pain in the arse to remove... I bought the AB stainless and have found them to be simple, effective and problem-free...
Old August 5th, 2010, 06:23 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Yeah - kind of the responses I was expecting. I have the stainless studs, and in reality, removal with a deep socket isn't that time consuming. Just looking for a better mousetrap that didn't cost $75.
Old August 5th, 2010, 06:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
Have you taken your door tops off yet? I wonder with the rust on your truck what type of nightmare you might have
Old August 5th, 2010, 06:55 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
I'm sort of prone to exaggerate, so while the rust is a pain, it's pretty localized to exposed areas underneath. I've seen some pretty well maintained trucks that look worse on the bottom.
The studs on the door tops actually came off without much effort. There was some rust, which was to be expected, but all in all, a little PB blaster and my deep socket and they were off the doors in minutes. Some more PB blaster and the vice grips and they were out of the windows. I replaced them with stainless and went on my merry way.
I just got interested in making the removal of them a bit easier and those speed nuts looked interesting. Not $75 interesting, but interesting nonetheless.
Old August 6th, 2010, 05:50 PM
d90dang's Avatar
d90dang
Matthew
1997 D-90
i have a set of 3 (yes i know im missing one) that are just sitting in my tool box
pm me an offer and there yours
Old August 6th, 2010, 10:10 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
I ran my IIA for years without the nuts -- on or off in seconds.
John Karlsson
Hope Valley, RI
Removal of Door Tops - Have Quick Nuts rijosho Defender Technical Discussions 19 May 14th, 2010 11:41 PM
Quick Release Nuts Photos/Opinions/Drawbacks? pcscharfe Defender Technical Discussions 6 October 4th, 2006 09:15 AM
Quick-release nuts for door tops - can anyone remember these? chittybangbang Defender Technical Discussions 20 May 30th, 2005 10:57 PM
Quick nuts for door tops dante18 Defender Technical Discussions 2 September 8th, 2004 12:09 PM
Quick Nuts - Where to buy them. Matt Klapmust Defender Technical Discussions 5 March 30th, 2004 11:52 AM
