quick exhaust manifold question - Defender Source
Old August 22nd, 2015, 12:55 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Hi all, doing the head gasket today on a 300tdi and trying to get the exhaust manifold off, but it will not budge. All bolts/nuts are off but I can't get the exhaust manifold to budge from the engine. I did not undo the bolts on the flange leading to the exhaust down pipe. Should I take a rubber mallet to the exhaust manifold or what should I do. I don't know how hard to hit it as it is cast and I have a tendency to hit things to hard then bad things happen. Any help?? pry bar??
thanks in advance
Old August 22nd, 2015, 01:10 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
No clue, but good luck Andrew. Hopefully this is just PM and not the result of some catastrophe.
Old August 22nd, 2015, 01:33 PM
USLandy's Avatar
USLandy
Andrew
defender 90
no catastrophe, yet... just being a pain in the ass. I just took the exhaust down pipe off and its still will not budge. probably never been off in the 100k miles its driven. I guess next best thing is to smack it with a big rubber mallet
Old August 22nd, 2015, 01:42 PM
bet you missed out the bottom center bolt under the turbo. don't hit it.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old August 22nd, 2015, 05:35 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Ren... After going back out there you are correct. before i started hitting it i checked again and felt that center bolt, came off easy after that.
exhaust
exhaust manifold alternatives J.5 Defender Technical Discussions 9 December 10th, 2008 01:46 PM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
exhaust manifold fire risk??! hlamar Defender Technical Discussions 2 August 2nd, 2006 08:00 AM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
