Quick ?, do front turn signal wires go directly to the relay behind fuse cover - Defender Source
Old January 6th, 2012, 06:55 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Question Quick ?, do front turn signal wires go directly to the relay behind fuse cover
I don't have a wiring diagram in front of me to figure it out. My front left light harness isnt' getting any power, if I'm correct, the wires go directly to the relay behind the fusebox? Need to fish out the problem. Any help is appreciated. Thanks
Robert Deniro
Old January 6th, 2012, 07:24 PM
93, 94 or your 97? I can go find my electrical manual, but it is for a 97.
Old January 6th, 2012, 07:45 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If it is only one side it is probably not the flasher connection. Each wing loom should connect to the main loom at the firewall, engine side. You may have a fuse for the Left and right side lights. If both the front and rear, on the same side, is out then it may just be a fuse. If it is only the front then I would check the connection at the firewall first.
Land Rover 110
Old January 6th, 2012, 08:23 PM
Neil McCauley
Neil McCauley
It's a 94. Trying to figure out why the harness gets no power, just trying to figure out where it goes back into before I visually follow it tomorrow afternoon at home.
------ Follow up post added January 6th, 2012 05:25 PM ------
I think that might be it since all the other 3 lights work except for the front left light. I need to find that connection now up there. Thanks!
Robert Deniro
cover, relay, signal
Turn Signal problems, '94 D90ST Nalu Defender Technical Discussions 3 December 30th, 2011 02:54 AM
RRC driver's side front amber turn signal light evilfij Wanted 2 November 15th, 2011 11:37 AM
Turn signal in the bumper! Bowtracer Defender Technical Discussions 20 June 7th, 2005 10:18 AM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
FS: D-90 Parts (Bikini Top, front bumper, wagon seat back cover, shift lever bezel dzientek For Sale - Parts 5 March 16th, 2005 12:09 PM
» Defender Registry
Broken
Z.G
The Beast
Corrina
Add your Defender
