Quick brake parts question - Defender Source
Old October 30th, 2014, 01:48 PM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
I need new brakes on my 1983 110. I want to replace at least the front rotors and pads
The few foreign parts shops around me (including AB, Eric was out) couldn't really verify what parts were correct for my truck.
I have the LR part numbers out of the LandroverWeb PDF, but that says 1987 onwards.
Front brake rotor FRC7239
Front brake pads STC2952
Is what it says. Can anyone confirm that?
Also, if I went into Napa or somewhere, what vehicle could I tell them it was for (that would be in their catalog) so I could just get the right dang parts for this weekend?
Thanks so much fellas.
Old October 30th, 2014, 04:02 PM
LRover's Avatar
LRover
J. Michael McCaig
My Parts manual says FRC7329 for the rotors which you may not need to replace unless they are thin, scored or have ridges. I don't have any info on a crossover listing for pads from another vehicle...sorry
Old October 31st, 2014, 10:44 AM
DannyboyUpstate
Danny Harrington
1983 110 3-door
Caved and ordered from Rovers North.
Old October 31st, 2014, 11:18 AM
According to the factory manual all 110s use the same pads from day 1. There are only two discs used, vented and solid. You should be fairly safe as long as someone did not play Lego with your truck at some point....
Old October 31st, 2014, 11:19 AM
Also, if you are replacing the discs, you need to remove the hub and will need a lock washer and should replace the hub seals.
Old October 31st, 2014, 11:34 AM
DannyboyUpstate
Danny Harrington
1983 110 3-door
Well shit.
Old October 31st, 2014, 11:37 AM
If you have not done this, you should probably have a read of the manual. Changing a disc on a classic Land Rover is not like a normal car.... Only replace if really needed. Changing pads takes 5 minutes.
Old October 31st, 2014, 11:38 AM
One last thing.... Make sure all of the caliper pistons are free (4 on each). They can rust in place.
Old October 31st, 2014, 11:48 AM
DannyboyUpstate
Danny Harrington
1983 110 3-door
Thanks John. Will do.
The rotors are visibly shot on the truck and the pads are just about there.
Old October 31st, 2014, 12:32 PM
DannyboyUpstate
Danny Harrington
1983 110 3-door
So you're talking about number 8 & 14 here?
Old October 31st, 2014, 12:39 PM
This is just me but I like to put a good lick of copper grease around the back of the hub where the rotor seats. Next time you go to replace the rotor, you'll thank yourself.
PS you can turn your regular disk brakes into vented disks by adding the spacers (and seals, and bolts) from a set of D1 or RRC vented rotor calipers to your calipers.
Old October 31st, 2014, 12:40 PM
DannyboyUpstate
Danny Harrington
1983 110 3-door
Haha. It looks pretty nasty. I'm thinking it's going to be a hammer and torch operation.
Old October 31st, 2014, 12:41 PM
Yes. Might as well get a 5 as well. some people use sealant, but I prefer gaskets myself.
On #14 order an OEM RTC3511 and not the FTC4785 listed in the manual. The RTC3511 is a better seal design and will fit fine.
Old October 31st, 2014, 01:08 PM
DannyboyUpstate
Danny Harrington
1983 110 3-door
Thank you.
Thank you.
Thank you.
For anyone who searches this later:
On an EARLY 110 front axle with a key cut in the spindle not a flat
#5 Joint washer = FRC3988
#8 Lock washer = 217353
Old November 5th, 2014, 12:42 PM
DannyboyUpstate
Danny Harrington
1983 110 3-door
OK! Job well done! Thanks for the tips fellas. It was well overdue! RoversNorth sent the wrong caliper pins, but Atlantic British came through in the clutch. Those 12 point bolts are no joke when they get old...
New rotor thickness = .554"
Old rotor thickness = .453"
Now I need to figure out why the truck has starter motor failures...
brake, part, parts
Quick Q?: front blinker lights with brake pedal BlackField Defender Technical Discussions 6 January 12th, 2014 10:20 AM
Quick Opinion Needed Powder Coat or Paint Alloy NAS 3rd Brake Light Bars SafariHP Misc. Chit-Chat 13 August 1st, 2011 08:12 PM
Parking brake light switch--quick fix Davis Defender Technical Discussions 1 May 18th, 2010 02:55 PM
Quick question, let's say you lose the rear brake line on a D90, is it dual circuit? evilfij Defender Technical Discussions 8 July 21st, 2009 08:05 AM
Quick driveline question D90user Defender Technical Discussions 2 May 11th, 2006 09:29 AM
