Questions regarding Steering damper - Defender Source
Old November 18th, 2004, 05:54 PM
Mark M
Mark Mathews
'94 Beluga Black ST
I just purchased a front skid plate from British Pacific. In order to mount the brackets I need to disconnect the steering damper and then re-install it through a hole in the bracket. Of course neither of the shop manuals I have has a single word about the damper. Can anyone tell me how difficult it is to remove and refit the damper? It looks like a shock or strut so I assume some force will be required to compress it. Any advice will be appreciated.
-Mark
Old November 18th, 2004, 07:28 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mark, it is a shock but it is not under any pressure. Just unbolt it and compress it by hand. Very easy.
Legend in My Own Mind.
Old November 20th, 2004, 02:45 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
yep, 10 minuite job!
Mike Hammond
Steering Damper Big D Wanted 3 September 6th, 2007 08:02 PM
OME Steering Damper Nut Sergeant_V Defender Technical Discussions 2 September 10th, 2006 04:16 PM
Bilstein steering damper JFD Defender Technical Discussions 0 August 14th, 2006 08:55 AM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
