Questions about replacing hub seals... - Defender Source
Old June 4th, 2004, 12:56 AM
discobro
Corey Wells
96 Discovery I
Just wondering if anyone on here can help me with direction on replacing my hub seals in my 96 Disco I. I just noticed oil all over the wheel the other day so it is either the hub seal (the oil is coming from a small cap in the middle of the hub housing) or the swivel ball axle seal. Where would be the best place to pick one of these up? RN? AB? EE? Anyone have experience with doing this and/or know where to buy them?
Any info is appreciated.
Thx!
Old June 4th, 2004, 08:47 AM
ronward's Avatar
ronward
Redsrover
None - sadly
You can call RN and ask for their hub seal replacement kit. Not sure the cost and it has been a long time since I bought one for my old D1. It is a simple job, just make sure you really clean and repack the bearing.
Old June 4th, 2004, 09:13 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
If you wheel your truck make sure you fit RTC3511 hub seals. These are the older type, but will fit all axles inc. Sali's. This is a double lipped seal & is much better than the newer type.
Sniff my Diff ;)
Old June 4th, 2004, 09:38 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Cory, check out Bill Burke's home page. There is an article about repacking/replacing wheel bearings and seals. www.bb4wa.com
Old June 4th, 2004, 09:41 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Here's a link with some pics: http://4x4wire.com/rover/maintenance...heel_bearings/
John C.
Old June 5th, 2004, 12:07 PM
discobro
Corey Wells
96 Discovery I
Thanks for all of the good info guys... I am going to spend some time this weekend servicing. Got Hub seals, tranny fluid/screen, new exhaust, stepper motor... Should be a fun weekend!
Thx again... C
ac, seals
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 02:46 AM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Replacing Vent Seals TND90 Defender Technical Discussions 3 January 14th, 2006 08:02 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Replacing ground wire questions vesparover Defender Technical Discussions 1 October 27th, 2003 04:01 PM
