Questions about Mantec tire carrier install - Defender Source
Old January 21st, 2013, 05:27 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I know a lot of people on this board have one so I thought I might get some guidance here. I took everything apart off my SW and was ready to put the Mantec plate on the back of the door and noticed a few things:
1. The instructions say all the existing hardware (bolts) is reused. I lined the thing up and maybe half of the holes on the plate match up with the existing holes in the door. Is that on purpose or am I supposed to drill the remaining ones?
2. Has anybody put some epoxy sealant around backside of the plate before install? The old carrier had some sort of a gasket on it but nothing comes with the Mantec Plate. There are three gaping holes in the door and while i'm sure moisture probably won't get it, it certainly could with enough rain. Thoughts?
3. Do I need a special drill bit to get through the rear crossmember? I have some generic bits, nothing fancy, but that is some thick ass steel. Do I need a Carbide bid or anything like that? Also when drilling, did you need to remove the rear step?
Thanks..
Old January 21st, 2013, 05:37 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I am pretty sure you do not need to drill the rear crossmember from what I remember it uses holes that are already there.
Are you sure you purchased the proper carrier for your door? There are 2 different types of SW doors
The only holes I remember drilling were in the capping but it has been a few years
Old January 21st, 2013, 05:40 PM
bjf's Avatar
bjf
barry f
94 ST #395
I drilled my crossmember to add it. Didn't need a special bit.
Old January 21st, 2013, 06:57 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Use a stepped bit:
http://www.irwin.com/tools/browse/dr...it-step-drills
The lower bracket does require an extra hole in the cross member. Good idea on the gasket. You could use something as simple as a silicone caulk which would make it removable, or cut a piece of rubber to sandwich in. I wouldn't mount it metal on metal.
Old January 21st, 2013, 07:50 PM
I used caulk on the rear door. Don't recall drilling agile but I have replaced my x-member so maybe later ones have the required holes.
Old January 21st, 2013, 08:36 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
There are two types for the SW? Mine is a 1995 NAS SW and I have no holes whatsoever. I pulled off the reflector and I have two tiny holes but none of the supplied bolts would fit through them. I would have to drill every single hole for the lower mount. Is that right?
Old January 21st, 2013, 08:37 PM
I'm pretty sure there are 2 models. One for earlier vehicles and one for later vehicles.
Old January 21st, 2013, 09:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yes you have to drill. Mantec makes two models.
Defenders pre 2002
Defenders post 2002.
I am referring to the style door. In addition Mantec has redesigned the lower mount. It used to angle up and cover a bit of the body. It no longer does that on any model.
Old January 21st, 2013, 09:53 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Ok thanks. I will drill and caulk the plate next weekend.
Yeah the lower plate doesn't cover any of the body, so I guess it's the updated version. Were you guys able to drill the lower bracket with the NAS step in place?
carrier, mantec, tire, tire carrier
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Mantec Swing-Away Tire Carrier david_jackson Defender Technical Discussions 16 December 17th, 2004 05:24 PM
Mantec Tire carrier Installation Questions Eric Siepmann Defender Technical Discussions 6 November 21st, 2004 01:42 PM
Cheapest MAntec Tire Carrier Nobrega Defender Technical Discussions 5 June 29th, 2004 03:21 PM
