Questions About Instrument Wiring - Defender Source
Old August 12th, 2016, 11:20 PM
RBBailey
RBBailey
1965 IIa
  1. Can't find where voltage is measured in the wiring diagram. Where is the best spot to measure voltage from?
  2. Is it OK to have instruments like the water temp gauge hooked up to 12v live all the time? (Key off and out, still with 12v)
  3. Is there any reason why I should not pig-tail the 12v to each of the 3 or even 6 instruments in line?
  4. Is there any reason why a fresh ground harness, pig-tailed in line from one instrument to the next should not be used?
  5. Would this hold true for the three instruments I need to wire the lights to?
Project:
1965 IIa SWB
Old August 12th, 2016, 11:27 PM
1. The Battery
2. No
3. That's fine
4. That's too is fine
5. Yes
Old August 13th, 2016, 12:01 AM
RBBailey
RBBailey
1965 IIa
About monitoring the battery: Should this be fused? Should it be relayed to the ignition so the gauge only registers when in run position?
I assume all 12v supplied lines need to be fused, if not already?
Thanks for the answers.
Project:
1965 IIa SWB
Old August 13th, 2016, 05:43 AM
Originally Posted by RBBailey View Post
About monitoring the battery: Should this be fused? Should it be relayed to the ignition so the gauge only registers when in run position? I assume all 12v supplied lines need to be fused, if not already? Thanks for the answers.
No fuse no relay on this particular circuit. You can use small stuff if it's a battery monitor but if this has an amp meter whole other story. Generally yes you fuse all circuits, this protects the WIRE not the thing being powered.
If this device has amp meter in it then it needs a shunt where main 12V hot goes to the wire harness supply. This way you see all the amps flowing from battery to truck.
Old August 14th, 2016, 01:56 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Unlike the newer truck not all of the older years especially series had all of the wires fused, mainly the brown wires and some white.
Land Rover 110
Old August 14th, 2016, 02:26 PM
RBBailey
RBBailey
1965 IIa
Yeah, I'm starting to track down the instructions for these gauges at various places online. Some are different than others, so it's frustrating. None of my gauges came with any instructions.
Project:
1965 IIa SWB
wiring
Wiring diagram for instrument panel Azarur Defender Technical Discussions 3 March 25th, 2014 10:21 AM
Wiring Questions usadventureracing Defender Technical Discussions 3 March 31st, 2012 04:43 PM
Wiring questions for split charge system aclarke Defender Technical Discussions 5 April 23rd, 2007 03:39 PM
Stereo Wiring Questions gtg067i Defender Technical Discussions 1 June 19th, 2005 07:10 PM
Instrument Panel wiring loykd Defender Technical Discussions 6 October 18th, 2004 09:16 AM
