Questions about fuel pump - Defender Source
Old June 27th, 2008, 01:28 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
Hi all,
My truck is at the shop in order to figure out what is going on with humming noise when the key is to the on position. The fellow said he thinks it is controlled by a pressure switch? but he does't want to start anything without a diagram or electrical schematic. Any suggestions?
Old June 27th, 2008, 01:48 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
There is no fuel pressure switch in there at all. The only sensor in the fuel system is a fuel temperature sensor on the fuel rail. It's a recirculating type system with a bypass regulator, normally it pressurizes the system and then shuts off after a fixed amount of time if you didn't start the engine. But it runs constantly while the engine is running, any extra fuel pressure is released by the regulator and run back to the fuel tank via the return line. So you're not going to burn out the pump, it's designed for constant use.
I'd start with testing the fuel system relays next to the ECU. There are two silver ones next to each other, one controls the O2 sensors power and the other the fuel pump. Swap them around and see if the problem changes.
My oil line fix
My 100k stopped odometer fix
Old June 27th, 2008, 07:55 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
PS. The "fuel temperature sensor" does not monitor the fuel temperature at all. It is installed in the fuel rail but has no direct exposure to fuel. It is there to tell the ECU if the engine is "hot", ie just got done running, or "cold". The ECU then uses the information to modulate starting the vehicle.
Just thought this would be nice for people to know. I thought it was a nice factoid when I heard it.
fuel
