Questions about boost diaphragm. - Defender Source
Old October 5th, 2016, 12:56 AM
SARTech
P. Barber
1989/Defender 90
I suspected my injector pump boost diaphragm was bad due to poor top end power and what seamed like a pressurized fuel tank.
I removed the diaphragm and it was indeed failed. it had a very large hole in it.
During the removal it was obvious that someone had removed the diaphragm before. The lock wire was no longer there. This is a new to me truck. 1989 Defender 90, 2.5LTD
My questions:
-The adjustment pin in the diaphragm was level (no protrusion) with the diaphragm. Is there a standard pin protrusion measurement?
- The longer pin in the pump that the diaphragm pushes on with increased boot. It was completely recessed and not visible. At first I thought that it was missing. It was way into the pump. Is that normal?
- Lastly the longer pin is housed in a hollow screw (carb jet looking thing). That hollow screw was finger tight. I was able to rotate it by hand. Assuming it should be tight I screwed it in until snug. Should it be tight or is there an adjustment as to where it should be set.
I have searched the web and not found any information.
Is there a US source for the boost diaphragm?
Thanks for any help.
boost
19j 2.5l td Boost Diaphragm Oasisplayer311 Defender Technical Discussions 5 July 29th, 2016 01:19 PM
NJ.. Blown IP Boost Diaphragm Help needed... icnsltmfg Defender Technical Discussions 6 November 14th, 2015 07:53 AM
Boost Diaphragm Delphi 7243-006 for a 2.5TD 19J icnsltmfg Defender Technical Discussions 3 October 28th, 2015 04:24 PM
Delphi Boost Diaphragm The Dro For Sale - Parts 8 September 20th, 2015 08:54 PM
