Question: Repainting NAS D90. Source for fresh correct decals? - Defender Source
Old September 22nd, 2016, 10:33 PM
BayouBeastie
Corky Jones
97 D90 LE ST Conversion
Dropped truck off at paint shop today. Clear coat is basically gone. Paint is in better than average shape. Will be prepping and redoing paint (Willow Green) and two coats of clear. Prepping pocess will remove left and right V8 decals as well as "Land Rover" at hood. In the experience of others that have gone through this, is there a preferred source for replacement decals?
Thanks for any help you all can offer.
Here's a pic of the stripped down truck for those interested in this type of surgery.
ID:	158206   Click image for larger version
Old September 22nd, 2016, 11:39 PM
There were V8 decals discussed like 12 hours ago
http://www.defendersource.com/forum/...rts-73207.html
I see you've removed the front cage - are you replacing the front portion? I remember I'd pointed this out to you when you first purchased.
http://www.defendersource.com/forum/...ans-58122.html
Old September 23rd, 2016, 12:02 AM
BayouBeastie
Corky Jones
Thanks for the link. Didn't see the earlier conversation - clearly the 2 hours I spend on this site daily will need to be upped.
Not replacing front portion. We removed as much of the cage as we could without getting over our heads too much. The portions we removed have been cleaned, prepped and powder coated. We will run new wiring for overhead lighting and satellite radio antennae inside this.
Also you might have noticed that we pulled off all of the LE diamond plate that we could. After some debate we have opted for not removing the two pieces on the front fenders as they seem to be attached with the standard screws as well as some VERY tough adhesive. Planning on taping them off and working with them in place. Hate cutting corners but I think this will be ok in the long run.
Will be undercoating everything after paint work is done. Also adding noise/heat deadening wherever possible.
Having a ball. Wondering what to divide by when I tell the wife what it's all costing.
Thanks again for your interest and help.
Old September 23rd, 2016, 12:42 AM
"4". And then she'll still say it's absurdly expensive.
Old September 23rd, 2016, 12:49 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Adhesive under the wing plate? Strange. Could it just be the foam pad bonded to the paint? Would it not slide/rotate after the screws/bolts were removed?
"Barry is correct!"
Old September 23rd, 2016, 03:00 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Clear coat huh
Interesting
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old September 23rd, 2016, 07:38 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by crown14 View Post
Clear coat huh Interesting Sent from my SAMSUNG-SM-N920A using Tapatalk
Weren't the LE's and BRG's clear coated?
Old September 23rd, 2016, 07:59 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
And the Belugas
Old September 23rd, 2016, 02:14 PM
BayouBeastie
Corky Jones
May be. I will take a closer look to see if it can be removed more easily than I originally thought.
Will try to remove screws and rotate. I was a little afraid of bending (creasing) either the panel or the plate. Rotating might mitigate this risk.
Thanks / Corky
Old September 23rd, 2016, 05:27 PM
Just my recommendation, but I've told you previously that the front cage portion that you have is meant for a SW, not a ST. If you're spending a significant amount of money redoing the truck, it'd be a shame to keep the front cage as is instead of spending the ~$1,100 to get the correct ST front portion of the cage. In all honesty you'd probably net out by selling your newly powdercoated SW front cage. Additionally, that SW cage was bent to meet with your ST padded cage, therefore changing the intended optimal geometry of the cage - if the worst happens (a rollover) I think you'd hate to see a catastrophic failure of the cage due to an already-weakened front portion.
Again just my two cents.
My post to you 3 years ago:
I'm actually talking about this. It looks like when they did the conversion from SW/Hard top to ST/Soft Top, that they didn't update all of the cage components, and instead just bent the front section of the cage DOWN to meet the rest of the cage.
Old September 23rd, 2016, 08:09 PM
BayouBeastie
Corky Jones
I'll bite. Any clues on where to locate ST front cage?
Also any issues in securing ST front cage to factory attachment points on the SW body?
Your vigilance is appreciated (and complicating).
(Also don't overlook the fact that I am 90% poseur.)
Cheers.
Corky
Old September 23rd, 2016, 08:22 PM
D90Overkill
David Frank
1995 ST #2615
I'll bite. Any clues on where to locate ST front cage? Also any issues in securing ST front cage to factory attachment points on the SW body?
Yes. The exact opposite of the problem you're having right now. But why? You have an ST.
Edit.... Oh, you mean the frame mounts for the A-hoop from the front wings? Those are identical. Lots of guys recently converted from ST to SW. Maybe you can swap with someone.
"Barry is correct!"
Old September 23rd, 2016, 08:26 PM
Chris B
72 + D1 drivetrain =?
[QUOTE=BayouBeastie;769602Wondering what to divide by when I tell the wife what it's all costing.
Thanks again for your interest and help.[/QUOTE]
She just registered as "Bayoubabe".
Old September 23rd, 2016, 08:28 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Do it right. Strip the entire truck.
Old September 24th, 2016, 10:10 AM
BayouBeastie
Corky Jones
Thanks. This is helpful. I'll create a WTB post to see if someone has one to swap.
------ Follow up post added September 24th, 2016 09:19 AM ------
News Flash --- Tell all your friends.
http://www.defendersource.com/forum/...tml#post769901
Old September 24th, 2016, 08:13 PM
crown14's Avatar
crown14
Verticalscrote
My comment was more about him getting new paint and "two coats of clearcoat". I mean, it worked out so well the first time, let's do twice as much this time.
Old September 24th, 2016, 11:01 PM
BayouBeastie
Corky Jones
I found the correct V8 decals for the left and right.
However I am having a tough time finding the front decal that matches the understated font of the original. See photo of original.
Any ideas where to find this decal? I checked through RN's collection but didn't see the exact match.
Thanks / Corky
PS Tried to get this photo to appear correctly.. Too tired to figure it out. You get the idea....
Old September 24th, 2016, 11:04 PM
Thanks / Corky
I could swear that RN used to carry them....BUT, unless you're being a stickler for "period correct" restoration....I'd actually take this opportunity to swap out for one of the below - I personally have always liked this retro-looking decal much better anyhow (the original NAS "Land Rover" lettering looked like Rover just sent someone down to the local hardware store for some stick-em letters or whatever they had on the shelf):
Old September 24th, 2016, 11:09 PM
BayouBeastie
Corky Jones
I could swear that RN used to carry them....BUT, unless you're being a stickler for "period correct" restoration....I'd actually take this opportunity to swap out for one of the below - I personally have always liked this retro-looking decal much better anyhow:
Thanks Jason. That's not bad looking. I am shooting for the ridiculously understated "LAND ROVER" if I can get one. If not RN has some that look like the modern version that actually goes on the front lip of the bonnet (rather than just below it like mine).
I'll keep it in mind. Thanks again.
Over.
Old September 24th, 2016, 11:14 PM
Over.
You don't want the bonnet lettering..those are the much bigger/newer versions.
Try these:
Defender 90 Land Rover Front Name Decal Tape Gray Raised Lettering Genuine New | eBay
Looks like it *may* be part #BTR8704MUL actually...and if that's the case, call Zack @ RN to confirm and you'd be better off ordering from him:
http://www.roversnorth.com/ProductDe...ode=BTR8704MUL
paint, d90, nas, 90
Repainting a D90 BMGmotors Defender Technical Discussions 23 August 13th, 2011 09:24 PM
Repainting the Rover SJVA Misc. Chit-Chat 2 May 31st, 2011 12:54 PM
ECR fresh NAS 110 rebuild with 300tdi, $160,000 evilfij The Flea Market 100 March 17th, 2011 01:11 AM
repainting tuffy console Abrooks Defender Technical Discussions 5 April 2nd, 2009 11:25 PM
Repainting 95 AA Yellow to Arles Blue Helihntr Defender Technical Discussions 36 May 4th, 2005 02:01 AM
