Question regarding engine numbers - Defender Source
Old March 26th, 2017, 11:18 AM
johnnydakota
1991 Defender 200 tdi
Hi all,
I am looking to import a defender, and just have a couple of questions regarding numbers. I always hear about matching engine numbers, but how do you tell if it is a matching number, as it doesn't have that 'spelled out' on the title? Is there a way to cross reference the engine number online etc? Or is it just that the engine number determine what type of engine it is 200 tdi etc? Thanks all!
Old March 26th, 2017, 11:25 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Originally Posted by johnnydakota View Post
Hi all,
Someone correct me if i am wrong but the key is the first 3 leading characters which tells the approximate year of the engine, and of course the model. For instance 200TDI's start with 11L, 12L, or 13L. 11L is 1990/1991. If customs sees a 12L in a 1990 truck, that is a red flag.
Put the VIN in here and it should tell you the prefix that you need the truck to have. The NHSTA/DOT use this same calculator for reference.
http://www.clifton.nl/index.html?calvin.html
Old March 26th, 2017, 11:55 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Clifton Scientific Text Services, the Netherlands
Am no expert that's for sure, but I thought that 11L was the Defender version of the 200TDI and the 12L was the Disco version, while 13L was the Range Rover 200TDI version.
RDavisinVA
Old March 26th, 2017, 12:02 PM
AdamSanta85
91' D90 200TDI
Originally Posted by rdavisinva View Post
Am no expert that's for sure, but I thought that 11L was the Defender version of the 200TDI and the 12L & 13K were Disco 200TDI versions.
Yea you might be right with that.
Regardless customs wants to make sure the prefix matches up with what LR says it should have.
Old March 26th, 2017, 12:04 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
You are 100% right, Adam.
RDavisinVA
Old March 26th, 2017, 04:25 PM
johnnydakota
Thanks guys for the reply that clears things up & thanks Adam for that website, very helpful indeed.
engine
Engine Mounts david_jackson Defender Technical Discussions 1 February 8th, 2006 06:48 PM
Help with engine not starting cbass Defender Technical Discussions 4 April 5th, 2005 12:12 PM
Engine Oil Leak Question ronward Defender Technical Discussions 0 March 22nd, 2005 09:38 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
Why can't I disconect the engine from the trany? kit Defender Technical Discussions 6 October 22nd, 2003 07:40 PM
