Question on rear suspension - Defender Source
Old February 8th, 2012, 08:02 AM
usadventureracing's Avatar
usadventureracing
Brett
110
Does anyone know how to remove item 12 (ball joint)? Does it need to be pressed out?
1983 ROW D110
1970 Series III (Parting out)
Old February 8th, 2012, 08:37 AM
Yes you remove the two bolts (14), cut the ears off so the press doesn't fight itself, and press it out.
How's the project going?
Originally Posted by pendy
I'm here for the D's
Old February 8th, 2012, 08:43 AM
usadventureracing
Brett
110
Thanks for the info. The project is going good. Should have a rolling chassis by the end of the weekend.
1983 ROW D110
Old February 8th, 2012, 11:03 AM
usadventureracing
Brett
110
No that is just the picture I took in the parts catalogue
1983 ROW D110
Old February 8th, 2012, 11:07 AM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
<http://www.repairmylandrover.co.uk/defender-repairguides/a-frame-balljoint-renewal>
John Karlsson
Hope Valley, RI
Old February 8th, 2012, 03:50 PM
usadventureracing
Brett
110
Thank you for the info I am going to try to pound it out first I have been soaking it with wd40 this week.
1983 ROW D110
Old February 8th, 2012, 03:58 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Find someone with a real press. When I replaced my ball joint, it took ~18-20tons of force to get it to move. Sounded like a cannon when it finally released. It took about a minute with the right tool. By hand, it could take ages to hammer it out.
1970 SIIA 88, Sold
Old February 8th, 2012, 04:04 PM
Naplm00
Matthew
if you are in my area with it ( i doubt it ) I have a 20ton H frame press that could get it done. OR if you have a real issue just send me the parts and ill remove and replace for you
Old February 8th, 2012, 05:05 PM
WD-40 is a water dryer... Pick up some penetrating oil, it will do a much better job.
Question for those with rack mounted rear work lights Manimal Defender Technical Discussions 31 November 6th, 2011 11:45 PM
Rear bench seat install question flounder Defender Technical Discussions 3 September 29th, 2011 01:29 AM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
suspension question - Scorpion asator Defender Technical Discussions 25 October 10th, 2004 12:24 PM
Rear Suspension Question dnewman9 Defender Technical Discussions 3 February 1st, 2004 06:31 PM
