Question on Bolts - Defender Source
Old January 26th, 2012, 10:14 AM
usadventureracing's Avatar
usadventureracing
Brett
110
Question on Bolts
Does anyone have a recommendation on what to use stainless bolts for and those items not use stainless? Is there a complete list of bolts sizes for 110s?
1983 ROW D110
1970 Series III (Parting out)
Old January 26th, 2012, 10:43 AM
Naplm00
Matthew
I put them everywhere there isnt a 12.9 or hardened bolt or stud. If it required the extra strength from the factory i wont replace it with the softer stainless.
Also i didnt replace some if i could clean up the original cad plating
Old January 26th, 2012, 10:57 AM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
Not sure if this is entirely applicable to the 110, but I pulled these lists from this forum a while back and have found them to be very handy - one covers interior, the other exterior. Hope this helps, Jeff.
Old January 26th, 2012, 11:37 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
What are people using when mixing stainless with carbon steel? I have the old jar of Permatex Copper anti-seize. Would this work or introducing copper just exasperate the problem?
http://www.permatex.com/products/Aut...ubricant_b.htm
Old January 26th, 2012, 01:11 PM
usadventureracing
Brett
110
Thank you, the list should help. My plan is to use the original bolts (cleaned up and replace with those I had to cut off) with anti-seize to get a rolloing chassis and any engine/trans mounting. I will then use stainless for everything else.
1983 ROW D110
Old January 26th, 2012, 01:36 PM
Naplm00
Matthew
I use the cheaper aluminum antisieze, either would work i guess. havent had any issues using this in the NE for years now
EDIT: now reading the permatex website they say that the nickel antisieze is for use with stainless.
Old January 26th, 2012, 01:52 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I have used the Permatex copper anti-seize as well as the Loc-tite copper sticks...have had mixed results with both. If you have SS threading through or into carbon steel on the underside you may want to consider just sticking with zinc and saving a few bucks. I replaced the visible body bolts with SS and have had no issues removing them when needed.
bolts
two bulkhead bolts...removal question Gkase Defender Technical Discussions 7 November 3rd, 2010 05:33 PM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
Bushing hardware question D90user Defender Technical Discussions 3 November 30th, 2005 03:54 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
