Question for the experts?? VNT turbo EGT probe placement - Defender Source
Old April 9th, 2016, 10:37 PM
BullTrout14's Avatar
BullTrout14
1985/Defender 110
Ok I just finished installing my Allisport VNT turbo but you cannot us the EGR block off plate to install my EGT probe as there is not enough of an opening there to fit it through. My question is this - since there is still some blow by coming out of this cavity ( see pics) can I not just drill a hole through the manifold within the cavity since there is already some minor exhaust coming from here and reinstall the probe I was using with the original turbo setup?
Thanks in advance for the help?
ID:	146867   Click image for larger version
Old April 9th, 2016, 10:42 PM
brian, can you explain more clearly why you can't mount the egt probe into the egr blanking plate?
From your photo there seems to be no reason that I can discern as to why the egt probe cannot be mounted on the egr blanking plate.
Old April 9th, 2016, 10:49 PM
BullTrout14
1985/Defender 110
Can't really see but there is no real opening in the cavity from to the manifold, moving my finger around there is no opening at all, started the vehicle and had exhaust coming from the lower bolt hole to mount the egt, put the bolt in the whole and now there is minor exhaust coming from the opening but minimal. Basically they didn't actually open the cavity to connect to the manifold as per the original?
Does that make sense?
Old April 10th, 2016, 01:37 AM
makes sense, thanks! I don't have an answer, but it looks like the VNT hotside housing is cast to blank off the EGR. Strange...
Old April 10th, 2016, 01:42 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
I have VNT but for Defender 200tdi. A question for you OP, did, the hot side have gasket that went between the downpipe and the turbo?
Old April 10th, 2016, 02:22 AM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
looks very similar to the stock manifold and egr casting. Could you weld the EGT probe bung to the blanking plate on a roughly 45 degree angle or what you think fits the best? That's basically what we did on mine for the stock setup a few years ago. Upside is blanking plates and bungs are cheap if you get it wrong.
1989ish 110 300tdi (Bella)
1988 LR90 ST 200tdi (Shorty)
1991 D130 200TDi (TBN)
Old April 10th, 2016, 02:27 AM
i think the issue is that the vnt egr casting is not actually open to the exhaust gasses
Old April 10th, 2016, 03:03 AM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
So you can reinstall the EGR and look like you're still compliant with the original emissions setup?
Old April 10th, 2016, 03:15 AM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
So the question really is would that lower bolt hole put you too close to the turbine wheel? you may be better off going through the top hole which looks like, with a longer probe, it should put you right where you want to be in terms of EGT.
Old April 10th, 2016, 09:24 AM
BullTrout14
1985/Defender 110
Sorry, the pic you posted is exactly the set up I had for my egt probe prior to installing the VNT, my question is since there is already some exhaust leaking but not an opening enough the get the probe through in the VNT egr cavity can I just drill a hole through the casting in the egr cavity big enough to fit the probe through and install it the same as I had with the original turbo?
Old April 10th, 2016, 09:51 AM
BullTrout14
1985/Defender 110
Basically my thought is to have the vehicle running, drill through the casting in the egr cavity with the exhaust gases pushing out any possible shavings, re install probe through drilled hole?
Anybody see any downsides to this?
Thanks.
Old April 10th, 2016, 11:06 AM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
Unless your 300TDi runs a lot smoother than mine, I can't imagine trying to drill while it's running. The hole shouldn't need to be too big to fit the probe through, so shavings should be minimal, most of which will end up in the cavity area. The rest will blow through once you run it.
Really though, there are people on this forum that are more knowledgeable than I on this. I also suggest that you ask Allisport directly. I expect they'll be pretty responsive and will be able to give you good direction. Can't imagine that most people installing this VNT don't go through the same thing where you'll be pushing EG temps.
Old April 10th, 2016, 12:05 PM
BullTrout14
1985/Defender 110
Thanks for the reply, am also waiting for Andrews reply to this from Allisport. I know most just drill and tap somewhere else on the manifold in this scenario but since I already have the blanking plate with the proper length probe in place and there is some exhaust gases escaping here already I just figured this would be an easier solution for me.
Cheers,
Help! 200Tdi VDO EGT probe location El Solis Defender Technical Discussions 49 March 7th, 2017 07:29 AM
200Tdi EGT Probe Adapter Plate? javelinadave Defender Technical Discussions 4 August 20th, 2016 10:45 AM
VNT turbo and EGT probe Talleyrand Defender Technical Discussions 11 May 24th, 2016 12:36 AM
Discovery EGT Gauge Placement smenzel Defender Technical Discussions 3 April 26th, 2013 06:47 PM
200tdi EGT probe location ... Retrofit Defender Technical Discussions 3 May 15th, 2007 12:16 AM
