Question: DOT Approved Headlights - Defender Source
Old October 14th, 2015, 10:35 AM
LRColorado
1990 Defender (200 TDI)
I want to upgrade my headlights and found a company out of the country that sells DOT approved headlights for Left hand drive vehicles, but not Right hand drive. If i buy and install these headlights what legal problems could come my way? By the way my Land Rover is Right hand drive. Also are lights designed differently for a left or right hand drive vehicle?
Old October 14th, 2015, 10:42 AM
It is not where the steering wheel is located that is important, but which side of the road you are driving on. The lights point more to the right from countries that drive on the right.
Old October 14th, 2015, 10:43 AM
ezzzzzzz
Mark Garrenton
RHD headlamps are designed to cast light slightly away from oncoming traffic. LHD headlamps do the same thing. Replacing your headlights with appropriate LHD lenses is the correct thing to do. There are numerous providers selling similar assemblies. You'll want to ensure the lenses are marked DOT to eliminate any issues during inspection.
Old October 14th, 2015, 10:48 AM
Only if you live somewhere that has inspections.... Ecode lights have a better pattern for both the driver and the the other cars on the road.
Old October 14th, 2015, 10:57 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
x2 If inspection issues are not a concern, this is good advice, the e-Code headlamps are much better for you and oncoming drivers, our lighting codes are so behind the times.
Edit: Heck, for me, even id there are inspection concerns, it would be worth it to just swap the stock sealed beams back in for the inspection, they are so easy to change out, and the light from the E-Codes so much better..
~Scott T.
'95 D-90 ST - AA Yellow
Old October 14th, 2015, 11:21 AM
LRColorado
Thanks for the quick replies. Makes sense to replace the RHD lights with LHD to be kind to oncoming traffic here in the USA.
Old October 14th, 2015, 12:21 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Here's the difference between RHD & LHD patterns.
Old October 14th, 2015, 09:42 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Cibie or Hella E code (not Hella Vision plus) are great. Il like the Hella's better, they are less costly and tougher then the Cibie's. Stay away from the no name Asian stuff.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
ht, lights
Brake fluid dot 4 vs Castrol 5 tomaco1 Defender Technical Discussions 9 June 18th, 2013 07:58 AM
Dot 4 fluid trybul Defender Technical Discussions 2 September 2nd, 2011 08:29 AM
Tenn. DOT is brillant part of a string of brillance airbornrover Misc. Chit-Chat 0 December 22nd, 2009 08:14 PM
7inch DOT approved LEDs ini88 Misc. Chit-Chat 7 June 26th, 2009 05:30 PM
EPA/DOT Compliance? gtg067i Misc. Chit-Chat 4 April 18th, 2006 04:07 PM
