Question: Defender rims - Defender Source
Old October 28th, 2015, 04:26 PM
LRColorado
1990 Defender (200 TDI)
Is the lug nut pattern on the Land Rover Defender unique or will most any rim work for this vehicle?
Old October 28th, 2015, 04:40 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
It is definitely different than most.. Bolt pattern is referred to as '5 x 6.5'. Essentially means 5 lugs, 6.5 inch spacing..
http://www.tirerack.com/wheels/tech/....jsp?techid=92
~Scott T.
'95 D-90 ST - AA Yellow
Old October 28th, 2015, 04:41 PM
Unique to Land Rover. Used on all Land Rovers until the end of the disco 1 and RRC.
Old October 28th, 2015, 04:46 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Still used on Land Rovers....
Old October 28th, 2015, 05:06 PM
The important word was "all".
Old October 28th, 2015, 05:26 PM
And Sankey trailers!
Old October 28th, 2015, 05:52 PM
LRColorado
Thanks everyone
Thanks everyone. I appreciate the quick response.
Old October 28th, 2015, 06:27 PM
you can always go searching around online for spacer adapters that'll bring you from one bolt pattern to another, but there are plenty of sexy wheels already available in the stock defender/D1/RRC, etc. bolt pattern to choose from. Like boosts.
Old October 28th, 2015, 07:01 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
FWIW, if you have older axles and/or drum brakes, the rims from a RRC/D1 will fit, but only without center caps as the hubs poke out too far.
That said, D1 axles will fit a Defender. Cheap, quick upgrade to disc brakes plus they have sway bar mounts...
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
defender, rims
FS: 4 w/ Spare 235/85R16 Federal Couragia w/ Black D1 Rims & Second 4 Set ATs w/Rims monktonrover For Sale - Parts 0 July 28th, 2014 10:20 PM
wanted used or good deal on defender steel rims Pig Pen Wanted 2 April 28th, 2009 07:36 PM
Defender Rims tpyle Defender Technical Discussions 4 May 20th, 2008 09:49 PM
WTB 4 Defender 90 Center Caps for rims Frankie Carbone Wanted 2 August 4th, 2007 08:43 AM
WTB Defender 90 Alloy Rims Frankie Carbone Wanted 1 January 18th, 2007 10:13 PM
