Question: Choke cable to choke lever on Weber/Edelbrock 4bbl carb - Defender Source
Old March 1st, 2011, 08:31 AM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
The previous owner of my 110 V8 installed a Weber/Edelbrock intake manifold and carb kit from RPI. He did not, however, install the choke cable. The Edelbrock instructions for connecting the choke cable to the lever are not very explicit, and I have dug through the internet in search of the "preferred method" of attachment. The cable has been run from the steering column through the bulkhead and around to the cable bracket on the carb, but I have not attached the cable to the choke lever itself. This is where I am in need of some terminal guidance.
Do any of you have the Weber/Edelbrock setup? If so, could you please let me know how you attached the cable to the choke lever? I'd greatly appreciate any suggestions and/or pics of how anyone has done this.
ATW!
- Jon
Old March 1st, 2011, 10:48 AM
Do you have a photo showing the problem? Usually they are pretty simple, a clamp to hold the cable housing and a "cable stop" of some kind to hold the inner part. If there is just a hole in the lever then you may need to buy something like this:
Old March 1st, 2011, 11:04 AM
LRover's Avatar
LRover
J. Michael McCaig
Yes, you may be missing the cable clamp that goes on the lever. I don't have a good picture of the cable actually attached to the carb on my engine but maybe these will help.
ID:	36306   Click image for larger version
Old March 1st, 2011, 03:24 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
Thank you, Ren. That part would definitely work. Now I just need to find one.
ATW!
- Jon
Old March 1st, 2011, 05:43 PM
usadventureracing's Avatar
usadventureracing
Brett
110
Mine edlebrock carb came with an electric choke, check to see if you have one before you hook up the manual.
1983 ROW D110
1970 Series III (Parting out)
Old March 2nd, 2011, 04:48 AM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
I definitely do not have an electric choke. That said, does the electric choke work well?
ATW!
- Jon
Old March 2nd, 2011, 12:23 PM
Jon
Almost every auto parts store in the US has a section where they sell little repair parts like this. One common brand is "HELP", they have a whole section of card-packed small items like this.
here is a nice one on ebay. if you can't find one where you are, for some reason, we can send you one from here.
http://cgi.ebay.com/ebaymotors/Weber...-/300435554342
Old March 2nd, 2011, 12:31 PM
usadventureracing
Brett
110
It seems to work great, I have not driven my car much (as for right now I do not drive my LRs during winter, too much salt here in IL), but while starting it in the garage this winter during very cold days, I have had no issues and from monitoring it while running it looks to work great.
1983 ROW D110
Old March 2nd, 2011, 02:05 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
I found the HELP brand cable stops on websites like NAPA and Autozone, but for some reason, I was unable to add them to my cart. I'll ask the local Landy mechanic if he knows where I can snag a few before I reachback to CONUS. Thanks again for the help. Pics of my carb below:
ID:	36336   Click image for larger version
ATW!
- Jon
edelbrock
Air Vent Lever Control - hi/low Flagg Defender Technical Discussions 23 November 18th, 2006 02:08 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
