Question? Battery box relays - Defender Source
Old April 1st, 2015, 09:08 AM
MGPete's Avatar
MGPete
Pete C
'95 D90 SW
Finally time for a new battery and when I bought my truck it had 6 Hella lights as well as a bumper mounted winch, all of which I removed soon after purchase. (capping the bare wiring)
I have a spaghetti mess of wiring and relays in my battery box, all connected to the battery and I want to use this opportunity of replacing the battery to remove all extraneous wiring/relays.
Can someone confirm that all of this mess can be removed?
Pete
ID:	117444   Click image for larger version
Old April 1st, 2015, 09:28 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Pete
Assume you will trace the wires before yanking anything but assuming they serviced only the lights then yes.
Old April 1st, 2015, 09:55 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
like jeff said, assuming you trace everything.
you can pretty much remove everything that is connected to the sides of the battery post terminals (not connected to the main cables). but trace them first, you might have a headlight relay setup in there as well as power feeds direct to your stereo/amps.
Old April 1st, 2015, 09:57 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Bringing up a separate note here is that if you do not have your headlights on relays, this could be a good opportunity to move them to a set to get the load off your headlight switch.
Old April 1st, 2015, 10:54 AM
MGPete's Avatar
MGPete
Pete C
'95 D90 SW
Good point about the amps. This thing had a super duper stereo/amp/speaker set-up when I bought it.
My real question I guess was in stock configuration, are there any relays or extraneous wiring attached to the battery terminals. Sounds like the answer is no. Thanks
Old April 1st, 2015, 11:03 AM
There is nothing stock there... But as mentioned, the stock design for power to the headlights is very, very bad and relays SHOULD be added. If the PO did add the relays, they should be retained.
battery, relay
Battery switch outside the battery box suggestions rankar Misc. Chit-Chat 7 December 25th, 2014 03:13 PM
modified battery box and seat box Fearnofish Smaller Projects 4 March 28th, 2014 11:16 PM
110 passenger side tool box/battery box? timtimtj Defender Technical Discussions 5 January 28th, 2014 03:14 PM
Galvanized Defender Battery Box & Tool Box James Pierce For Sale - Parts 9 September 3rd, 2010 10:23 AM
fuel pump and relays? steved90 Defender Technical Discussions 5 September 11th, 2006 03:57 PM
