Question about Mallory Unilite distributor & Coil combination compatibility - Page 3 - Defender Source
Old June 16th, 2016, 02:14 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Update: Thanks all. I called Mallory. They recommended 8202 with ballast resistor.
Old July 13th, 2016, 08:28 PM
BritishAutoworksSD
Peter Campbell
none
Hi Guys,
I know this is an old thread but figured I drop a couple lines.
93' D110- Owner has a MSD Marine Ignition Controllor, Bosch Coil (1.1 ohms) and Mallory Distributor 4768901. Recently replace ignition pickup module with Mallory 605. Ran great for about 100 miles, then stumbles and misfires like crazy. Tempted to remove MSD box and install ballast resistor.
Anyone else had problems with a MSD box in this setup?
-Thanks,
Peter
Old July 13th, 2016, 08:51 PM
User Name
User
NAS D90 '95
Originally Posted by BritishAutoworksSD View Post
Hi Guys, I know this is an old thread but figured I drop a couple lines. 93' D110- Owner has a MSD Marine Ignition Controllor, Bosch Coil (1.1 ohms) and Mallory Distributor 4768901. Recently replace ignition pickup module with Mallory 605. Ran great for about 100 miles, then stumbles and misfires like crazy. Tempted to remove MSD box and install ballast resistor. Anyone else had problems with a MSD box in this setup? -Thanks, Peter
The problem is the ignition controller gotta go factory. You can do Mallory coil and distributor but you will lose your mind trying to get that to send the right signal. Remove, test, you're right.
Old July 13th, 2016, 09:22 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Any idea why the the ignition controller was introduced into the mix? It is not needed. I'd remove. Good idea to install the Mallory 700 ballast resister, or equivalent from JEGS for $15. Considering the 700 is now becoming NLA, check out the price of this hoarder! I just purchased a spare last month for $24. LOL. Should have grabbed a few.
ID:	153798   Click image for larger version
Old July 13th, 2016, 09:31 PM
User Name
User
NAS D90 '95
all of these work great with the factory ignition module
- DIST,BUICK V8 215-350 UNIL VA..... Part No. Mallory # 4764301 MSD # 8548
- Mallory PROMASTER(r) Coil Part No 29440
- Active Power Filter . . . . . . . . . . . Part No. 29351
- Replacement UNILITE(r) module - part # 605 if you need to replace a burned out one.
trust me. i had the HYFIRE® 6A ELECTRONIC IGNITION CONTROL Part No. 6852M
and
- Mallory tach adapter.... Part No. 29074
- Mallory Ignition Ballast Resistor Part No. 700
in the mix. all a bunch of parts that i kept buying to come to the conclusion that the MSD box isn't compatible.
Old July 14th, 2016, 10:32 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
So, was the factory ignition module a NLA Lucas part or was it actually the same Unilite part that User Name is citing?
Has anyone had issues with the combination of parts that User Name is recommending?
Old July 14th, 2016, 11:05 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Active Power Filter is NLA. It got nixed by MSD when they bought Mallory. I talked to them directly about a replacement and there is not one.
Old July 14th, 2016, 01:02 PM
cowboy
steven
So, does anyone have an idea for a substitute?
Old July 14th, 2016, 02:13 PM
down_shift's Avatar
down_shift
Russell
Why do you think it needs the active power filter? Going on 9 years w/o on mine.
Old July 14th, 2016, 03:25 PM
User Name
User
NAS D90 '95
The power filter was a precaution that hasn't bothered anything.
------ Follow up post added July 14th, 2016 04:29 PM ------
the unilite ignition module goes inside the Mallory distributor
Old July 15th, 2016, 05:09 PM
BritishAutoworksSD
Peter Campbell
none
Downshift-
Which plug wires are you using? I'm removing the MSD box and installing a ballast resistor this weekend. I want to make sure I get quality wires to prevent noise to the Mallory 605 pickup
Old July 15th, 2016, 05:48 PM
down_shift's Avatar
down_shift
Russell
Downshift- Which plug wires are you using? I'm removing the MSD box and installing a ballast resistor this weekend. I want to make sure I get quality wires to prevent noise to the Mallory 605 pickup
Mallory Pro Sidewinder 8mm Silicon Suppression Wire. These were installed in 07'.
Old July 15th, 2016, 07:38 PM
User Name
User
NAS D90 '95
Magnecor 85196 8.5mm KV85 CN Series Ignition Cable 1989-1996
coil, distributor
Ignition Coil question, when + side is charged, should the - side be charged as well? Neil McCauley Defender Technical Discussions 2 November 23rd, 2010 02:54 PM
Mallory Distributor, Coil, Magnecor Wires, ect. Paul Grant For Sale - Parts 0 November 15th, 2007 07:03 PM
Major Wire problem-- dash dissasembly. Need help. Ignition Mallory Unilite Heath Defender Technical Discussions 22 August 29th, 2007 11:35 AM
Mallory Unilite Distributor Davis Defender Technical Discussions 5 April 9th, 2005 04:00 PM
Odd intake compatibility question for Rover Tech types Hans Defender Technical Discussions 3 December 13th, 2004 06:39 PM
