Question about Mallory Unilite distributor & Coil combination compatibility - Page 2 - Defender Source
Join the Defender Source Community Today
Old May 10th, 2012, 11:15 PM
jijalicious
Jiman Khosravan
'94 D90
Neil,
Can you post a picture of your setup please?
~jij
Old May 11th, 2012, 04:14 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by jijalicious
Neil,
~jij
Not sure if Neil will see this but I have a similar setup and can grab a pic. What do you want to see specifically? Coil? Dizzy?
Old May 11th, 2012, 04:49 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by jijalicious View Post
Neil,
~jij
For what it is worth, the following Mallory parts were installed on 1/07:
Distributor MAA-4768901
Coil MAA-29219
Ballast Resistor MAA-700
This setup runs like a champ with zero issues to date.
ID:	51450   Click image for larger version
ID:	51452   Click image for larger version
Old May 11th, 2012, 04:55 PM
jijalicious
Jiman Khosravan
'94 D90
Sorry if it's too elementary in the explanation...
My current setup:mallory unilite distributor w/ e-spark module... with balast resistor.. with an accel coil....
So from the distributor, 8 of the connections go to the spark plugs. The 9th one in the center of the distributor goes to the accel coil.
The coil has a female connection, and so does the distributor.
Mallory coil 30451 is a male connection. How to you install this? Need to change my plug wire to something else? Or what am I not getting?
Looks like my coil is going bad when hot so I rather upgrade to the "correct" setup with the malory unilite then just buy another regular coil and have it break in 10K miles.
~Jij
The mallroy coil that
Old May 11th, 2012, 05:05 PM
jijalicious
Jiman Khosravan
'94 D90
The only difference between this and mine is the accel coil 8140...
Maybe this accel crap is just that.. crap??
Coil MAA-29219
------ Follow up post added May 11th, 2012 05:09 PM ------
Here's another "hmmmmmmmmmmm'.. when I got this truck.. the coil was upside down... as in the connector is on top....
Are these coils only meant to be installed with the connections on the bottom???
Old May 11th, 2012, 05:12 PM
down_shift's Avatar
down_shift
Russell
Sounds like you need to source a wire with a female plug on one end and a male on the other. That, or go with the Mallory canister type coil MAA-29219. Here is a pic of the two versions, 29219 on the left and the 30451 on the right.
ID:	51454   Click image for larger version
Old May 11th, 2012, 06:13 PM
The orientation of the coil does not matter.
Originally Posted by pendy
I'm here for the D's
Old May 12th, 2012, 12:52 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I'm looking for pics right now, but I didn't use an oil filled coil, I used the epoxy filled coil that dosen't need a ballast.
Look at my other thread, I have pics of the coil in there.
Robert Deniro
Old May 14th, 2012, 05:53 PM
jijalicious
Jiman Khosravan
'94 D90
Neil,
Just want to see how you connected 30451 to the distributor and where you installed it... and if it is what Russel said.. that i just need to find/locate a spark plug cable that is male-female... and be done.
Thanks for looking for pics
~Jij
Old August 18th, 2012, 01:02 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by MudD1 View Post
So I have a Mallory dizzy and had been using a NAPA coil and resistor.After reading this thread I bought the Mallory coil from Amazon. Two months later the truck up and dies on me.I found that the optic sensor in the dizzy was bad.I replaced it and it still would not run.Turns out the new coil went bad.Mallory says the optic sensor usually goes bad due to a voltage spike.I wonder if I had a voltage spike due to NoT running a resistor?
Jeff
I might be having the same issue as you Jeff.
The other day, backing out the driveway - truck just dies. Go to crank - and no start. Later in the day I start to diagnose --- hear the fuel pump, smell some fuel after cranking. Swapped ECU, checked ignition fuse.
Checked a plug for spark and nothing. So I start checking out the dizzy/coil.
1 - Searched the interweb and found how to test coil. I got 1.9 ohms which seems high as Neil said he got 1.4 and I tested another Bosch coil I had which read 1.2.
2 - Also found this video: First part of the test I got 10volts - covered the optics and there was no drop.
Sent Mallory tech support a ticket from their online form but figured I would cross reference with this thread as it came up in my google searching.
I am wondering if I am getting a voltage spike or there is something wrong with my system that I have blown coils, ballast resistors and maybe now a module. Or is the Mallory stuff just not that durable???
If anyone has any tips please let me know. This has been the most frustrating ongoing issue with this truck. Thanks
------ Follow up post added August 18th, 2012 01:03 PM ------
Originally Posted by TS888 View Post
I'm SO glad I have a diesel now...
I have been tossing this around. This might be the issue to put me over!
Old August 18th, 2012, 01:14 PM
Neil McCauley
Neil McCauley
Neil,
~Jij
The coil install is very simple. It's just + and -, 2 wires to the -, one to the +. The same wires that go to your stock coil.
Robert Deniro
Old February 20th, 2016, 09:11 AM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
http://www.summitracing.com/parts/maa-4768901
Not available or out of stock! Need one ASAP!
Sal
Old February 20th, 2016, 09:14 AM
phoenix37's Avatar
phoenix37
john
http://www.amazon.com/Mallory-476890...ywords=4768901
Old February 20th, 2016, 09:25 AM
budzny
Real4X4
Will check, thanks!
Sal
Old February 20th, 2016, 09:36 AM
phoenix37's Avatar
phoenix37
john
one more
Mallory 4768901 Unilite Electronic Ignition Distributor Series 47 | eBay
Old June 15th, 2016, 11:25 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hi all. So neither of these coils are available (from my searches) anymore. Anyone have an updated suggestion? Thanks in advance!
Old June 16th, 2016, 10:23 AM
down_shift's Avatar
down_shift
Russell
Regardless of this recommendation for the coil # 29216, a quick search through Google says this coil is not the best option. I'd call Mallory directly and ask for their recommendation.
Here some other areas to consider for the folks experiencing problems.
Josh, do you have a hulking sound system and CB in your D? I am not running the active power filter or curve change kit.
ID:	152049   Click image for larger version
ID:	152051   Click image for larger version
ID:	152053   Click image for larger version
Old June 16th, 2016, 10:36 AM
Davis's Avatar
Davis
Chris Davis
94 D90, 88 RRC
Mallory was bought by MSD, so most of the Mallory stuff is discontinued. FYI.
Old June 16th, 2016, 12:19 PM
Yes of course - amp, 10" sub, etc. - doesn't everyone?!?! CB isn't hard wired though. I got the truck running earlier this week by literally advancing the timing a degree or two (no start) then retarding it a degree or two - started right up and ran for 5 minutes then died. Brought it back to where it was originally (i.e. where it hadn't been starting), and it started right up and has been fine since. Makes no sense. I've driven it 4 hours this week without issue though, so I'm baffled.
Old June 16th, 2016, 03:13 PM
Davis's Avatar
Davis
Chris Davis
94 D90, 88 RRC
For what it is worth, my coil went out and I went to Pep Boys and got the Master Blaster 2 coil with ballast resistor. I am running the Mallory distributor. It has been in for a month and everything is fine.
coil, distributor
Ignition Coil question, when + side is charged, should the - side be charged as well? Neil McCauley Defender Technical Discussions 2 November 23rd, 2010 03:54 PM
Mallory Distributor, Coil, Magnecor Wires, ect. Paul Grant For Sale - Parts 0 November 15th, 2007 08:03 PM
Major Wire problem-- dash dissasembly. Need help. Ignition Mallory Unilite Heath Defender Technical Discussions 22 August 29th, 2007 12:35 PM
Mallory Unilite Distributor Davis Defender Technical Discussions 5 April 9th, 2005 05:00 PM
Odd intake compatibility question for Rover Tech types Hans Defender Technical Discussions 3 December 13th, 2004 07:39 PM
