Question about hinges? - Defender Source
Old December 13th, 2014, 11:36 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Hi there,
I'm putting new hinges and hardware on and was wondering if the Longer bolts bolt into the bulkhead or the door?
Also, how do you tell which hinges are for which side?
Thanks in advance.
Old December 13th, 2014, 11:39 PM
Originally Posted by Vunkle View Post
Hi there, I'm putting new hinges and hardware on and was wondering if the Longer bolts bolt into the bulkhead or the door? Also, how do you tell which hinges are for which side? Thanks in advance.
Longer bolts for the door.
Hinges should have a part number you can lookup. Also if you get it wrong the doors won't open correctly.
Old December 13th, 2014, 11:47 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Thanks. All of this is pretty new too me.
Old December 13th, 2014, 11:59 PM
If I recall correctly the thicker part of the hinge goes up and obviously the hinges with 6 holes are the top hinges.
Old December 14th, 2014, 03:28 AM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
I could try mounting the mirrors on the bottom of the door. Get that street level view going.
Old December 15th, 2014, 10:45 AM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
One more question. How many hinge shims should I use? Or does that very?
Old December 15th, 2014, 11:24 AM
One shim. Unless you have something twisted.
Old December 15th, 2014, 11:37 AM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Thanks again. You guys are the best!
Group Buy (feeler): stainless steel door hinges, safari door/bonnet/bulkhead hinges nathanwind For Sale - Parts 52 November 30th, 2011 04:58 PM
hinges dmarchand Misc. Chit-Chat 62 December 23rd, 2004 10:02 AM
Door Hinges Krna Misc. Chit-Chat 0 February 10th, 2004 06:52 PM
motosource hinges tonymotosource Misc. Chit-Chat 0 December 9th, 2003 09:50 AM
New non-corrosive alloy door hinges and bolt kit c2sox Misc. Chit-Chat 24 December 8th, 2003 03:16 PM
