Question about burning smell - Defender Source
Old March 5th, 2006, 07:26 PM
michael15's Avatar
michael15
Mike Schlueter
1995 Red D-90
I have a funny burning rubber smell coming from my 90.
I recently had a new Transfer case and Trans put in. I am about 2000 miles into them.
When I drive at highway speeds for about 20 minutes I can smell a burning rubber smell.
Any thoughts?
Thanks a lot
Sorry
Had A Thread Right On Topic.
Appreciate The Looks Though!
If Anyone Has The Definitive Answer I Would Still Love To Hear It.
Old March 5th, 2006, 09:26 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
I`ve got the exact same problem, stemming from the exact same situation, no difinitive answer, but the truck is being worked on currently and we think it is that the clutch is slipping in 5th gear. I`ll let you know how it goes once I get the truck back.
Old March 5th, 2006, 09:57 PM
michael15's Avatar
michael15
Mike Schlueter
1995 Red D-90
I would really appreciate that - thanks.
For the record - I just had my trans case/tranny replaced so something in the clutch might make sense.
thanks
Old March 5th, 2006, 10:16 PM
oldscratchggf
nate
95 d90
Yea, I had just had mine replaced when my truck started smelling. I had the tranny, clutch, fly wheel, thorw off bearing, and rear engine seal all replaced, so that sort of rules out your t-case. Is the smell ONLY while in 5th gear for you as well?
Old March 6th, 2006, 09:36 AM
michael15's Avatar
michael15
Mike Schlueter
1995 Red D-90
Thanks for the response again. I found your thread and emailed you directly earlier. Not sure if you have gotten it yet or not.
Mine definitely seems to burn when I am at highway speeds for 20-30 minutes. I thought it was only in 5th but I THINK (not sure) that it was doing it at highway speeds in 4th also.
Man do I hope your mechanic figures this out for both of us.
Old March 6th, 2006, 12:05 PM
It really could be allot of things. But Mike you had a new tranns and tcase installed but you kept the old clutch?
Old March 6th, 2006, 12:16 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
i had a burning smell at most speeds.Mike H could smell it driving behind me at 70mph.mine smelt like a sewer,it was the T/C fluid burning
3rd low and BOOT IT
Old March 6th, 2006, 02:28 PM
michael15's Avatar
michael15
Mike Schlueter
1995 Red D-90
Mike -
The clutch was only 3-4000 miles old. I had that replaced 5 or 6 months ago.
Old March 6th, 2006, 04:03 PM
oldscratchggf
nate
95 d90
So what was the fix for that?
Old March 6th, 2006, 04:24 PM
He changed the fluid 3 or 4 times, and it still smelt like rotting flesh mixed wth swamp azz and a hint of burning rubber, it also screamed very loudly, sounded like an airplane. So he replaced the t-case. You could always stick your finger in the fill hole of the tcase and get some oil on it then smell your stinky finger.
Old March 6th, 2006, 10:00 PM
oldscratchggf
nate
95 d90
Found out today that that buring smell was the smell of all my synchros having the shit eaten out of them. The shop that rebuilt (and by rebuilt it turns out they actually meant replaced it with a remanufactured tranny from some other shop) the tranny didn`t put in the correct oil.
Old March 7th, 2006, 09:56 AM
michael15's Avatar
michael15
Mike Schlueter
1995 Red D-90
I almost GUARANTEE that is the same problem I am having! Dammit!
Now I talked to my shop and they are telling me that they for sure used Dextron 3. Is that what was supposed to go in it. Rovers North says thats the right stuff.
I am getting more concerned!
Thanks for keeping me/us up to date!
Old March 7th, 2006, 12:34 PM
oldscratchggf
nate
95 d90
Well you will know pretty soon whether or not that is the same problem that you are having. When I first got my truck back, it was doing OK, but by about the time I put another 1500 miles on it, the synchros were grinding in 2nd and 3rd. I don`t quite understand how exactly a tranny works, but my mechanic said something to the degree of the burning smell was most likely that the synchros were constantly spinning or something, which wore straight through them.
Old March 7th, 2006, 01:30 PM
artm
Arthur Maravelis
97 SW
There are conflicting opinions about using ATF in the R380. There's a company in the UK that developed their own fluid to settle the issue.
Do a search here for MTL. I've been using it for over a year in the 110 without any problems or concerns.
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
The sweet smell of exhaust!! bd90 Defender Technical Discussions 2 February 1st, 2004 07:46 AM
