Question - Defender Source
Old August 31st, 2004, 08:44 AM
GCOBIAK
GREG KOCH
97 D-90 LE
Question
Wondering If A Cruise Control Unit Is Available For A 97 D-90, Automatic?
Old August 31st, 2004, 09:58 AM
In addition to this after market unit and install instructions cruise control is available from the factory on current defenders.
http://www.the12volt.com/cruises/cruises.asp
http://www.rostra.com/cruise-control.htm
Old September 1st, 2004, 01:15 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Cruise control in mine wouldn't work. No way the mechanism could pull hard enough to get the throttle open to make it stay at freeway speeds. Very heavy foot works OK.
Old September 1st, 2004, 07:45 AM
pendy's Avatar
pendy
jim pendleton
89'd90
That rostra unit will work on a diesel injection pump with automatic. Very strong electic motor to set the cruise speed with.
You have to use a relay to supply a brake signal though if I remember. I have installed about 6 of them. Many on diesel LR's.
Jim Pendleton
legend in my own mind
Old September 1st, 2004, 09:09 AM
what about a hand throttle not exactly cruise control but........
Old September 1st, 2004, 12:04 PM
..........but brutally unsafe!
Old September 1st, 2004, 12:18 PM
it will keep you on your toes tho.
Old September 1st, 2004, 12:45 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
And void your insurance at the same time.
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
» Defender Registry
Lola
Anni
Elbee
Add your Defender
