QT rear diff guard rubs gas tank - Page 2 - Defender Source
Old March 21st, 2009, 08:21 PM
I have the Southdown rear dif guard, it helps slide over things and does not touch the gas tank.
Old March 22nd, 2009, 11:50 AM
Dave, the only problem with self clearancing a plastic tank is that it will eventually end up with a hole. I took a picture yesterday and will upload later. With Steel, you'd just have a dent in which case I'd just say get-r-done!
Randy, that's certainly an option. I already did my front.
Thanks Scott, I'll look into it.
Old March 22nd, 2009, 06:21 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I never knew the tanks were plastic. Shows you how much I know NAS!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 22nd, 2009, 06:34 PM
No worries. Actually after good look I think I'll just grind off the sharp edges on the QT guard. I dont think it can cause any damage if its got a rounded smooth edge.
http://lhsw.com/gallery/d90_fuel_tank/DSC03873
http://lhsw.com/gallery/d90_fuel_tank/DSC03875
As usual this damn project has taken on a life of it's own. Since I'm treating and preventing rust on the rear cross member and frame back to the middle cross member, I went ahead a pulled off the tire carrier and light bar since I have some rust on those too. Will hopefully get those powder coated after cleaning them up
charles
Old March 22nd, 2009, 06:45 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Charles, how much clearance is there between the guard and the diff cover? You might be able to remove it and bend it in a little there to give more clearance between it and the tank. You might even be able to do it in place, but if you need to heat it I would be weary of doing it so close to the tank, especially with a known fuel leak.
Old March 22nd, 2009, 06:50 PM
There is more clearance than necessary right now between the guard and the cover. I think it's a result from impact on the bottom side of the guard bending the bottom in and the top outward/rearward, and you are right I should be able to adjust it to be a tighter fit, giving me more clearance. I would have thought of that on my own. I swear. really.. ok, maybe not Thanks!
Tank is out, so no worries there. Since I'm tearing crap apart I'm seriously thinking yanking the axle and doing a sewer cap, but otherwise adjust what I have is going to be what I'll do.
charles
Old March 22nd, 2009, 07:50 PM
go ahead and put a pipe cap on, i think itll hold a little more 90wt than stock cover.
Old March 23rd, 2009, 08:53 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Oops. No offense to Keith, but I just realized I misquoted my trailing arm brand. They are rover tracks.
And very happy with them Doug, thanks
Hard to tell what the bottom of that one looks like. Know of any other pics? I think I need to save my pennies for that sexy rockware rear suspension kit!
Tyler, who sells the rovertym stuff?
www.rovertym.com
Jimmy Buffett
gas, gas tank
Gas tank guard cover problem... FlaD90 Smaller Projects 9 April 28th, 2008 09:28 PM
WTB: NAS 90 rear gas tank headdamage Wanted 11 March 8th, 2005 02:46 AM
QT services rear diff guard JKM Defender Technical Discussions 2 May 16th, 2004 07:50 PM
