QT 3 link - Defender Source
Old February 11th, 2011, 09:57 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
QT 3 link
I have searched for this, and can't find that anyone is using it on a D-90. It is a pricy kit, but includes the mounts to move your front shocks outside the springs, the longer shocks, new drive shaft, and all the other parts needed for the 3 link. When you consider all of that, it is still pricey, but you get a lot more than you ever did with the SG kit.
I am curious is anyone is running this set up, or knows anything about it. Also your opinions on $ vs. what you get.
That is why it is called a short cut. If it was easy it would just be "the way."
QT Drag link photos crown14 Defender Technical Discussions 8 December 8th, 2009 01:43 PM
WANTED QT 3 link setup mud ruts Wanted 0 October 4th, 2009 09:06 PM
Home design 3 link system UKlandyandy Defender Technical Discussions 65 February 17th, 2005 09:09 PM
Fusable Link by batt on 92 RRC...? RedRhinoProducts Defender Technical Discussions 5 February 6th, 2005 07:23 PM
